Noise in NC Prop
Sad-Ham
Noise in NC Prop
Postby Sad-Ham » Mon Jun 23, 2014 7:55 am
After yesterdays flight I was wiping exhaust residue my prop and tapped one of the blades.... There is what sounds like a rattle noise coming from the inside , almost as though there is something loose inside. Does anyone konw what this could be or where I can send the blade to have it checked out?
Aquilla II ZU-DJS
Wingfield - 124.8
Station Kariba
Re: Noise in NC Prop
Postby Station Kariba » Mon Jun 23, 2014 11:14 am
Hi Sad-Ham
Get hold of Nigel Coutts directly, his details as follows
Cell # 084 629 3730
Landline 011-788 3297
He can advise. Hope this help and good luck.
Graham Galloway
Z-RUM
Z-TOC
Z-HAY
Sad-Ham
Postby Sad-Ham » Mon Jun 23, 2014 11:55 am
Thanks... will contact him
Aquilla II ZU-DJS
Wingfield - 124.8
Sukkelaar
Postby Sukkelaar » Thu Jun 26, 2014 9:24 pm
Must be one of the balancing rods he puts in the stub of the prop and then glues in, that has come loose.
Im sure he will fix it
Kyk Noord
kloot piloot
Postby kloot piloot » Thu Jun 26, 2014 10:21 pm
I've never flown a NC prop but I have huge respect for them.
Fellow club member had a glove go through one on take off and it smashed the PU foam inside it, but the carbon fibre skin kept all together for a 10 minute flight back to base.
And: Local is Lekker ! vhpy
Roel Jansen
ZU-IAR powered by BMW 1200
Postby Bundy » Fri Jun 27, 2014 5:02 am
kloot piloot wrote:I've never flown a NC prop but I have huge respect for them.
Best decision we made when rebuilding DBP! Awesome product... more thrust, less RPM in the cruise, better fuel consumption. (^^)
Planning to send ours back to Nigel after about 300hrs for a "re finish" and check up too. The only thing rattling so far are the marbles inside my head. ^
Sad-Ham
Postby Sad-Ham » Fri Jun 27, 2014 7:47 am
Thanks guys... spoke to Nigel and he also said it must be the balancing rods.... will take it off this weekend and have a look
Aquilla II ZU-DJS
Wingfield - 124.8
