Low EGT on one cylinder Rotax
Makoppa
Postby Makoppa » Tue May 27, 2014 8:31 am
Hi fellow Aviators
I am flying a Xenon gyro with a Rotax Turbo motor. My cockpit is equiped with a Oddysey Stratomaster system, indicating inter alia EGT on each cylinder as well ad 2 CHT readings.
On my return flight yesterday from Cumberland to Rustenburg I noticed that the one EGT reading indicated around 450 whilst all 3 others indicated a normal 790 range.
I am not a petrol head, but did not experience any recognisable drop in power.
Any ideas pls?
Cobus Enslin
Nacho
Re: Low EGT on one cylinder Rotax
Postby Nacho » Tue May 27, 2014 8:54 am
1. Swap the probes if possible and see if the problem also moves, if it does, it is a temperamental probe. Replace it. It is normally very easy to swap the probes. Might be a faulty probe.
2. If the problems still persists it might be a dead plug, meaning you are running on 3 cylinders. Use the same method of troubleshooting, swap the plugs around.
Do the above on the ground, run the engine up and do your checks like that. This is not a big problem I am sure. Will take 30min to do both of the above tests.
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
Turbo
Postby Turbo » Fri Jun 13, 2014 6:55 am
Probes, spark plugs and carb balancing -- id check these in that order.
lion
Postby lion » Mon Jun 16, 2014 8:49 am
Was flying in a group with a Xenon - same problem - simple....egt probe loose...tightened and problem gone.
Koevoet
I hate bird strikes
I hate bird strikes
Postby Koevoet » Tue Jun 17, 2014 10:47 am
Recently same problem, [one needle was broken] new gauge problem solved.
Very happy Scout Piloooot
