This is attach to a used 503. This device attached to the magneto end starter.
It seems faulty and i like to replace it. Any idea where i can find it?
tx
What is this
Re: What is this
If it is connected to the starter then it is the Solenoid, i.e. the relay for the starter.
Effectively you use a light current, i.e. a thin wire from the starter switch to enable the solenoid. The solenoid then uses a thick plate to connect the two fat wires together and the starter turns. A normal starter/ignition switch can never handle the high current the starter motor draws
Try any Midas shop.
Try any Midas shop.
- Solenoid.png (7.81 KiB) Viewed 3372 times
Re: What is this
Morph wrote:If it is connected to the starter then it is the Solenoid, i.e. the relay for the starter.
Try any Midas shop.
Re: What is this
Thanks............so good. Will get it..
Re: What is this
Greg,
Same here. Looking up at every sound higher than 10 feet!!
Ampere, sorry for the high jack.
Re: What is this
I had the same problem on my windlass wen we fit n starter , ja the blerriesollenooi dont work so i go to grobbies scrapjaard in Warmbad en buy one from n old ford escort kArretjie for cheap and it work well willempie
Users browsing this forum: No registered users and 52 guests
