Running Jabi engin on mogas
Can a Jabi engin run safely and permanently on Mogas or is Avgas the only option?
- KFA
Re: Running Jabi engin on mogas
I have owned 2 Jabi powered aircraft. An Explorer and I still have my Safari and they run 95% on Mogas 95 and we have had zero trouble. The key lies in the installation setup of the engine. It is not a plug and play engine so my fisrt question will be. In which aircraft do you plan on installing the engine?
I am interested in buying a Jabi 120/160/170 or even 230. Availability of Avgas is a problem as I fly from the farm. Thus a standard Jabiru aerie.
- KFA
The cooling in the Jabi airframe is Ok for the application but a bit marginal at slow flight so I would recommend AVGAS but best is to check with Jab operators on the AVCOM Jabiru forum.
Thanks for the advice
- Solo cross country
- Location: Circus Airfield - 2 miles north of Henley on Klip
My advice
One word.
Don't !!
One word.
Don't !!
