I had to remove a wheel to repair a puncture. (Replace the tube)
Once the wheel was split, and the tire and tube removed, I noticed that there is no spacer between the two inner races of the bearings. In effect, this would mean that once the wheel nut is tightened, it places a side load on the inner races of the bearings. The wheel nut is secured with a split pin, and was not tight or difficult to remove.
So .... should there be a spacer, or not?
