Rubber Pumps
LarryMcG
Rubber Pumps
Postby LarryMcG » Mon May 29, 2006 12:03 pm
Hi All
A recently bought trike - only about 40 hours total time - had one of those
marine rubber hand pumps for pre-priming carbs. This one had a bypass tube, which sucked fuel back each time the pump was released, so I decided to remove the bypass.
On completion, there was a hole, or tear in the pump, which proved to be very brittle, and completely perished on the inside. The hole thing tore very easily, and had large flakes and strips pealing off on the inside. This all on the wrong side of the fuel filter.
It would only have been a matter of time before these bits and pieces caused an engine out, by going directly to the carbs.
Larry
Postby Morph » Mon May 29, 2006 2:05 pm
Larry,
I have heard from other sources that these pumps are extremely risky and should be avoided at all costs. Thanks for your input.
Slow_Poke
Postby Slow_Poke » Mon May 29, 2006 2:32 pm
Larry, microflight aviation urged me to remove the primer pump/bulb because of the same problem!
Postby Duck Rogers » Tue May 30, 2006 6:52 am
Like I've said before.......it's a piece of equipment that doesn't belong in a plane :shock:
Read this entire thread:
viewtopic.php?t=1619&postdays=0&postorder=asc&start=0
Junkie
Postby Junkie » Tue May 30, 2006 8:13 pm
Yup.. got rid of those pieces of @#^% fast and replaced with a push/pull primer pump.. I dont have chokes at all on my 582
Note though that the push/pulls also get gumbed up and need to be replaced at some stage - mines about 400 hours and gets stuck every now and then. Time to dump it too
J.U.N.K.I.E 's
No credit / No returns
DarkHelmet
Postby DarkHelmet » Wed May 31, 2006 8:27 am
Just install an electric standby fuel pump and bob is your auntie!
Hot Stuff
Survived first engine out
Postby Hot Stuff » Mon Apr 30, 2007 2:10 pm
From experience, its a bad piece of equipment to have on your trike. The quicker you loss it the better
