Windlass trike engine out after steep turns
GHJ
Heard about flying
Postby GHJ » Fri Jan 04, 2013 10:13 am
Hi, anyone who can help with this please?Hubby has a trike, and have used for a number of hours, also did his training with the trike, using a highly accredited flying school and instructor.
On Monday, 31 Dec, early morning, after quite a storm the previous evening, it was still quite cloudy and overcast, we flew for about 40 minutes, including some steep turns. On our way home (fortunately with runway in sight), the engine started to stutter (it is even less funny than a person stuttering :-)). He switched off one of the magnitos (?) and switched it back on again and the engine appeared to be fine. We landed safely. He checked everything and found a little water in the carburettor(?). He cleaned it, checked for water all over and took it for a test flight later in the afternoon. He repeated the manoevres of the morning, no problems. He has been flying everyday since then. Yesterday he checked everyting again and we went flying in the afternoon. This morning, 4 Jan, he went flying again, did steep turns and again the engin shut down. I think he repeated the process of the magnitos and he landed safely. It just boggles the mind why this happens.
I please need help urgently because he is obsessed with flying, if weather permits, he is out at 5 in the morning for an hour or so, and in the evening, at around 6 or so, he is off again.
Thanks!
KlapperKnop
Re: Windlass trike engine out after steep turns
Postby KlapperKnop » Fri Jan 04, 2013 10:40 am
This sound like the floats in the carburettor needs replacement or it gets stuck, running out of fuel in one bowl.
ZU-DJE
Alkemac
Postby Alkemac » Fri Jan 04, 2013 11:09 am
Also check for perforated floats - help with the process of elimination.
Just thinking about it now, it could also be that there is water in the bottom of the fuel tank - maybe with the steep turns, the water is being displaced and moving around at the bottom, eventuall being sucked into the fuel line ?
ZU-DODO
GHJ
Heard about flying
Postby GHJ » Fri Jan 04, 2013 12:56 pm
Nope, he emptied the fuel tank yesterday to check for exactly that. When he re-filled, he didn't fully empty the cannister, in case of water in the cannister. I'll enlighten him about the floats, will provide feedback. Thanks!
Kalahari
Survived first engine out
Postby Kalahari » Fri Jan 04, 2013 8:51 pm
Hi GJH
You did not mentioned the engine type but I assume it is a 503 or 582 Rotax? What type of fuel filter does he use? Did he checked the float levels? Where are you based, and what are the size of the main jets?
Arrogance and rudeness are the training wheels on the bicycle of life for those who can not keep their balance without it!
Goose
Postby Goose » Fri Jan 04, 2013 9:40 pm
Hi GHJ
It sounds like carb icing to me.
Goose
KFA
Postby KFA » Sat Jan 05, 2013 12:11 pm
Carb icing I would say. Was he descending with reduced power?
Postby nicow » Mon Jan 07, 2013 7:41 am
Goose wrote:Hi GHJ
Goose
Agree
