Call Sign
- Dish
Re: Call Sign
Your talking about the letters on your registration ??? Yes there's a definite spec that they need to be and nope, can't make em as you wish,,, (some okes would make them about 2cm high) - not sure what they are exactly but someone will know
RV9
DISH
DISH
Re: Call Sign
From SA-CATS-ARM
7. Specification of marks
(1)The nationality and registration marks must consist of capital letters in Roman characters without ornamentation.
(2)The width of each letter (except letter “I”) and the length of the hyphen must be two-thirds of the height of the letter.
(3)Each letter must be separated from the letter which immediately precedes or follows it by a space equal to one-third the height of the individual letters, the hyphen being regarded as a letter for this purpose.
(4)The lines forming the letters and hyphen must be solid and the thickness of those lines must be one-sixth of the height of the letter.
8.Measurement of marks
(1)The nationality and registration marks must be formed of letters of equal height, and must be so situated as to leave a margin of at least 50 mm along each edge of any surface to which they are affixed.
(2)The height of the marks on lighter-than-air aircraft must not be less than 500 mm.
(3)The height of the marks on aeroplanes and gliders must be –
(a)on the wings, not less than 500 mm; and
(b)on the fuselage or equivalent structure and on the vertical surfaces, not less than 300 mm, except that where the surface is not large enough to accommodate full-size marks the Commissioner may approve marks of a lesser measurement provided they are not less than 150 mm in height and can be readily identified.
(4)The height of the marks on rotorcraft must be –
(a)on the bottom surface of the fuselage or cabin, not less than 500 mm high; and
(b)on the sides of the fuselage or cabin, not less than 250 mm high, except that where the surface is not large enough for full-size marks the Commissioner may approve marks of a lesser measurement provided they are not less than 150 mm in height and can be readily identified.
(5)If an aeroplane or glider does not possess parts corresponding to those mentioned in the appropriate subparagraph of this paragraph, the marks must appear in such a manner that the aircraft can be readily identified.
- BOATCH
Re: Call Sign
Thanks got it.
Re: Call Sign
I didnt see anywhere where it stipulated whether or not they could be transparent
Re: Call Sign
You really say what we think.
__________________________________________________
wow gold|Diablo 3 Gold|wow gold kaufen|Buy Diablo 3 Gold
Users browsing this forum: No registered users and 42 guests
