Hey All
I am looking for Plastic welders int he Westrand JHB area. I have some cracks in a fuel tank that i need to have somebody look at.
Gavin
Plastic Welders in JHB / Westrand Area
Re: Plastic Welders in JHB / Westrand Area
Gavin,Tailspin wrote:Hey All
Gavin
Was that fuel tank used for clean petrol or mixed with 2 stroke, if mixed throw it away and get another tank. Been their done that and got the t-shirt, plastic welding does not work then specially on a two stroke with the vibrations it keeps on leaking and cracking.
Flying feeds the soul!
DamnJvTonder wrote:Gavin,Tailspin wrote:Hey All
Gavin
Was hoping i could get my 60L tank sorted for Numbi - would have made life so much easier, now got to do 6 fuel stops instead of 4
- ZULU1
Gavin, I will post this on open forum for all that may need this service. I own the tooling for a injection moulded cap that is attached to a roto moulded bottle, this is used for a cooling suit water bottle. 80 mm in diameter, it may be fitted to a simple roto moulded jig. Simply weld up a square or odd shape or whatever or whatever, attach the threaded neck with a simple clamp and it may be moulded to suit. Ideal for low volumes of product. Contact these guys http://www.eastcoastmoulders.co.za/bout ... dings.html
very easy solution.
Ciao Paul
very easy solution.
Ciao Paul
Thanks Paul
My Problem is the Tank has cracks in and I need the cracks fixed.
Although this is a good Idea and i can use it to make the small tank it will not work for the larger tank.
But will keep this in mind when doing the tank for the Long EZ.
BOUNCE
