Sticky throttle
Bugwar
Sticky throttle
Postby Bugwar » Fri Jan 21, 2011 1:27 pm
The throttle on my Raptor gets stuck every so often. I had the throttle cable replaced but it happened again.
Any suggestions?
It is not fun having to cut the engine for a dead stick landing every now and then. As it always stick in the full open position the trike continues to climb and the engine will not restart until the throttle is back (or close to) in the idle position.
ZU-EHG - Raptor
Vulture Squadron videos
Nacho
Re: Sticky throttle
Postby Nacho » Fri Jan 21, 2011 2:21 pm
* Replace the cable and the cable housing. Don't only replace the cable. My housing was the issue not so long ago.
* Make sure of your cable routing.
* Check your connection box make sure it operates smoothly. (Where the one throttle cable, connects to the two cables that goes to each carb)
WvB aka Nacho
0847014988
wvbosch@gmail.com
ZU-FFS (-)
Big-D
Re: Sticky throttle
Postby Big-D » Sun Jan 23, 2011 9:42 pm
Same thing happened to me - No fun. I had a AP replace the whole throttle system (Housing and cable)
Not the kinda thing you wanna mess with, Imagine it gets stuck 1hour away from home - Can only run engine on full RPM for a while and then have to switch off or risk damage - Not nice
D
Big D
wiskeyfoxtrot
Re: Sticky throttle
Postby wiskeyfoxtrot » Mon Jan 24, 2011 7:00 pm
Had the same propblem on my Raptor a while back. Next to the pedal there is a long bolt and nut that stops you pressIng the throttle beyond its max point. That had bent and was jamming the throttle wide open, bent it slightly and no more problems... mabey yours is the same?
Hope it can help you..
Later
Aeroprakt A22 Foxbat
ZU - DYE
Sport Cruiser
ZU - LSA
Bugwar
Re: Sticky throttle
Postby Bugwar » Tue Jan 25, 2011 12:05 pm
wiskeyfoxtrot wrote:Had the same propblem on my Raptor a while back. Next to the pedal there is a long bolt and nut that stops you pressIng the throttle beyond its max point. That had bent and was jamming the throttle wide open, bent it slightly and no more problems... mabey yours is the same?
Later
Unfortunately not the problem.
It seems as if it may have something to do with the "instructor's throttle" cable. When it sticks I can get it unstuck by pushing the back throttle couple of times.
Problem is it sticks randomly, which makes it difficult to find the problem
ZU-EHG - Raptor
KFA
Re: Sticky throttle
Postby KFA » Tue Jan 25, 2011 1:19 pm
Had a problem with the instructor throttle getting stuck and it happens where the cable comes out of the sleeve by the pedal. When you use the front throttle the tension in the cable is taken away and the back cable creeps out of the sleel sleeve and it gets stuck on the side of the steel. One way to fix is to wire tie the cable sleeve to the steel sleeve adjuster at the pedal. Hope it makes sense. Is the throttle getting stuck like full throttle or is it just idling very high?
Bugwar
Re: Sticky throttle
Postby Bugwar » Thu Jan 27, 2011 12:06 pm
Sticks full open 6000 rpm
ZU-EHG - Raptor
Big-D
Re: Sticky throttle
Postby Big-D » Thu Jan 27, 2011 12:12 pm
My advice - Stop messing around with a very dangerous situation
Get pro to sort out for you (Gideon Niemand will come out to your hanger)
D
Big D
KFA
Re: Sticky throttle
Postby KFA » Thu Jan 27, 2011 12:43 pm
The problem is either a routing one or it is the splitter slide that gets stuck. Have it checked out.
