Optifuel Installation
Alpha
Postby Alpha » Thu Oct 21, 2010 3:40 pm
Hi All,
I have just recently purchased a new optifuel system and was wondering if anyone has fitted this system to their aeries? The question I have is this, I am running a Rotax 503 with dual carbs, the sender unit can be placed between the fuel pump and the carb and I can set the sender to half flow. Or I can install it between the filter and fuel pump, to measure the flow rate before the fuel gets to the fuel pump.
The question is this, which installation would be better? (**)
Gary
ZS-WGT
ZU-AAS
John Young
Postby John Young » Fri Oct 22, 2010 6:39 am
Alpha-A-Sierra wrote:Or I can install it between the filter and fuel pump, to measure the flow rate before the fuel gets to the fuel pump.
To measure full flow is better. :wink:
John ZU-sEXY
Alpha
Re: Optifuel Installation
Postby Alpha » Fri Oct 22, 2010 6:54 am
Hi John,
Thank you for that, I will then install it that way, I agree I also think full flow should be measured.
Once again thank you.
Gary
ZS-WGT
ZU-AAS
Postby Morph » Fri Oct 22, 2010 9:14 am
Install it between the filter and the pump. Before the filter your sender will be subject to potential dirty fuel that could cause the sender to stick. After the fuel pump the pulsing flow sometimes causes erratic readings.
Alpha
Postby Alpha » Mon Oct 25, 2010 7:03 am
Thanks Morph,
Installed it this weekend between the filter and the pump. Now I just need to calibrate it. Thanks guys for all the advice.
ZS-WGT
ZU-AAS
