Currently considering buying an ultralight with a Rotax 582.
Wondering whether there's any important comments I should be aware of before buying?
Depending on plane type etc, I do understand, but does the 60hp Rotax offer enough power? Even on the highveld?
I'm planning to do some cross-country flying, hence the power and dependability is important to me across numerous geographies..
Thanks!!
Rotax 582 - Comments [Sorry, note it's a 503 - My apologies]
Len M
The knack [to flying] lies in learning how to throw yourself at the ground and miss.
Re: Rotax 582 - Comments
What ac and how many hours?
- Biggles
How big are you and will you be taking a big pax. Also the wing type will have a bearing on whether the 582 is the right engine. AFAIK, the 582 is good on the highveld unless two large people up.
Trike pilot
ZU-DLP
Winelands FAWN
ZU-DLP
Winelands FAWN
Das GermanGerman wrote:What ac and how many hours?
It's brand new, only run a few hours...
Len M
BigglesBiggles wrote:How big are you and will you be taking a big pax. Also the wing type will have a bearing on whether the 582 is the right engine. AFAIK, the 582 is good on the highveld unless two large people up.
Thanks for the inputs. I'm 90kg's (not sure whether that's big?! Careful now...
What I was hoping for is: "Hell no, stay away from that Rotax is dodgy!!"
Considering the absence of such comments, I'll assume it's a perfectly fine motor, when operated in a responsible manner.
Thanks!
Len
Len M
- Duck Rogers
The 503 is virtually bullet proof, but a little anemic on the Highveld with 2 upLenM wrote:What I was hoping for is: "Hell no, stay away from that Rotax is dodgy!!"
Good to know, thanks!Duck Rogers wrote:The 503 is virtually bullet proof, but a little anemic on the Highveld with 2 upLenM wrote:What I was hoping for is: "Hell no, stay away from that Rotax is dodgy!!"
Len M
Re: Rotax 582 - Comments [Sorry, note it's a 503 - My apolog
Agree with Duck,
Nothing wrong with 503, but ...
90kg + 60kg "luggage" + fuel on a high density altitude day at highveld elevations is not the ideal.
In cruise mode no problem, but that climb rate (when you need it) is SOOO slow
Roel Jansen
ZU-IAR powered by BMW 1200
