The not cold starting 912s
Stephan van Tonder
Postby Stephan van Tonder » Fri Aug 07, 2009 3:12 pm
So here is our little saga of the hard cold starting 912s. Last year in August when I started Flying with Andy he complained of the 912s Starting hard in winter. It really was a problem and gut wrenching when you turn the key and the engine goes clang and kicks back against the starter. So I jump on the internet and look for causes. I find a document from rotax and they say - low power supply or possible too much gearbox free play. Andy gets it checked out by Gideon and the gearbox gets re-shimmed and magically the starting problem disappears - we are happy. Summer arrives and she flies some 300 hours till may this year. Comes the real cold - and there we go again clang.. So out comes Gidoen - gearbox gets re-shimmed again - couple of grand later seems ok for a few days - back to clang... I ask questions about battery and wiring - nope has been checked out and battery is replaced. Three weeks later- clang - another trip into the gearbox with no happiness. Gideon, Aviation engines and rainbow now decide - prop is too heavy(P-prop) - sprag clutch is stuffed and so the engine has to be lifted and the prop has to be changed. We not convinced - besides we work out this little trip looks like in excess of R30k.
Yesterday me and Andy flies to tedderfield after struggling to get her going and we notice the charge seems low - 13.2v - we think 13.8 should be more like it. Back at petit we make a couple of calls and Niren and Gideon thinks 13.2 is ok. Me and Andy don't think so. So off comes the cowling and we dive in there with a multimeter. I test the battery - 12.6 standing with nothing on - not bad - 12.7 or 12.8 would be better but seeing the charge rate is so low - not bad. Next port of call - see what the starter gets. With using the motor as a ground and checking during cranking the starter gets 10.1V - eish - not good. So we decide to double up the wiring to the starter and I look but can't find a decent engine earth so we bring one from the battery to the motor direct. Now under cranking the starter gets 11.2v. Much better. Charge is still low though. We go around the other side and test the voltage out of the rectifier and I use the rectifier's casing as earth - sure as heck 13.8 volt with the motor just above idle - shift the earth test point to the engine - 13.2V huh?. Look at the rectifier earth - iffy little wire - goes somewhere on the firewall to another iffy wire. We make up another decent earth - motor to rectifier. Immediatley the actual charge rate goes up to 13.6 on the system. We scratch some more and find another 0.1 volt drop over a fuse from between the rectifier to the connect point for the battery. We lay another fused wire and now we have close on 13.7v on the battery. Happiness. We let it idle a while to charge the battery.
This morning I get a very happy phone call - she starts first time - no kicking back and the charge is good.
Not what has us a little miffed is that between 2 AMO's and the engine agent they can't have found the wiring problems in over a year after Andy spent thousands on getting gearbox shims done. And he asked about wiring before. Anyway - she is still a magic little plane and the motor is good now that we have spent R50 on wiring it properly. If we have left it to them we would have spent a huge bundle and still got nowhere.
I have said it many times - 99% of electrical issues are earth related and there it was yet again. So gents - check those engine and rectifier earth wires out if she struggles to start and charges low. Have a good weekend
Re: The not cold starting 912s
Postby Morph » Fri Aug 07, 2009 3:23 pm
That's 100percent of what we found on mine as well. Replaced the puny earth with a nice thick 10mm, cable. Huge difference. Starts on second swing everytime
Postby Duck Rogers » Fri Aug 07, 2009 4:49 pm
Nice post Stephan. A lot of guys should hopefully learn a lot from this.
Rudix
Postby Rudix » Fri Aug 07, 2009 5:54 pm
I agree, nice post Stephan.
I have an earth to check....
Fly safe,
vernon11
Postby vernon11 » Fri Aug 07, 2009 6:32 pm
Rudix wrote:I agree, nice post Stephan.
Fly safe,
Hallo Rudi,
How is the S12 Doing? Do you still have the 618 on? I have now completed my savannah. Just busy with the paper work.
Cheers,
Vernon.
Rudix
Postby Rudix » Fri Aug 07, 2009 6:59 pm
Fly safe,
Hallo Rudi,
Cheers,
Vernon.
Hi Vernon!
Yes, I still have the S12 and it still flies almost every weekend with the 618. It almost had a 912EX, but at the last moment I diverted the 912EX to my new Savannah since the 618 is still 100%! Hope to have the Savannah flying in 2-3 weeks!
Glad to hear your Savannah is finished, hope you can get the paperwork sorted soon! You must come visit....
Mogas
Postby Mogas » Sat Aug 08, 2009 12:33 pm
Well done Stefan
Testimony to the fact that "owner maintenance" works!
Nottaquitta
bosbok
Postby bosbok » Sun Aug 09, 2009 7:39 am
Stephan, great post !
Miskiet
Postby Miskiet » Wed Aug 12, 2009 6:31 am
I aggree with all - great post. It just shows if you take the time to educate yourself it is possible to exceed the quality of work of "supposed" experts. After all it is your life and no one will take better care of it than you.
As an extra comment - When you guys crimp fittings on the end of electrical cables please solder them thoroughly afterwards. It provides corrosion protection for the copper and guarantees a 100% connection for years to come. Crimp only will cause troubles in the years ahead....
German
Postby German » Wed Aug 12, 2009 5:09 pm
What I have experienced is it cracks off just where the solder stops at vibrations!
Ian
Postby Ian » Wed Aug 12, 2009 8:34 pm
Great post Stephan, gonna save plenty guys money in the future (^^)
Agree with German, solder, unless you have a cable support is no good in these vibrating environments. Better to use a self vulcanising tape over the crimp.
Has anyone got comments on the new product (Rotax have rated it highly) that retards one ignition circuit for starting ?
Cheers ian
Stephan van Tonder
Postby Stephan van Tonder » Thu Aug 13, 2009 10:43 am
I have looked at that ignition box and think it's a good idea. Quite costly though. Also not sure if available locally so Guess you'll have to import. I did suggest it to Andy already but he is not all that keen.
http://www.bullyhawk.com/index.htm
