Will do so yes. Would not mind becoming and qualified technician/mechanic on microlights myself. Will come to the next meeting and chat to you guys.
Two stroke carb settings
Re: Two stroke carb settings
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
Last wednesday of the month, from 19h30 at clubhouse at Morning Star.
You can also pop in any sat morning, we are usually there as well.
Going to attend the model airshow at Robertson this weekend. Cant miss a chance to fly my plane on the 1,5km x 15 wide runway
If not for that I would of been there this Sat. Will be there the next one then plus on the last Wednesday of this month. Your BB is coming on nicely I see. Where does oom Boet stay? And is is flying back here, or is it gonna bee on a trailer?
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
Loeriesfontein, about 320km N-NEfrom Capetown, as the crow flies. In the middle of nowhere, near Calvinia and Niewoudtville
It's an aerie, she will be flown back
That sounds good. Never knew a BB was covered by material ad the doped to harden - must be to keep the weight down I suppose. Really like the look of your plane Morph- the colour scheme ect. I have learnt on my model plane (since I started flying petrol engines. This spesific one is actually run on 95 and two stroke oil not methanol as previously commented ) that you need to either use lock-tite or some sort of holding device on each and every nut & bolt to prevent failure. Liked the method one of the members showed with the metal washer folding and holding the bolt in place.
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
Combination of heat plus doping. Heat really tightens it up, then you Nitrate it to waterseal teh fabric and prepare it for the next step, Then Butyrate it mixed with Aluminium paste to UV protect it, then spray with 2K and a plasticiser.
All the nuts and bolts are nylocs.
Ok a bit more to it than I thought. WOuld be good talking to yourself aswell at the meeting or club one day. You must have quite a bit of knowledge after building your own plane.
If I understand correctly you can only use those nuts once.
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
Yes only once. Certain critical bolts such as prop bolts are also safety wired.
Building your own aircraft is an amazing experience and you learn a hell of a lot doing it. If you get the opportunity definately do it.
Morph, last question and then I'am done (proberly sounding like n small boy - hoekom, maar hoekom)
Is n microlight plane allso inspected whilst you are building and you can only build so far unless a inspector has approved it? Or is this only for large and oversees builders?
Over and out
Over and out
Take to the sky
ZU-CBI
Aerotrike Scout
ZU-CBI
Aerotrike Scout
yes, a few major inspections. First the wings, before covering. Next the fuselage before covering, third the engine installation. And then there is a major inspection done prior to test flying.
Now some people combine the different inspections. The most important is they need to be able to check it all before it's closed up.
Then of course is the whole test flight thing. Quite nerve racking but a wonderfull achievement if it flies true hands off
- Duck Rogers
Flies ok, just doesn't land so good. Tends to wanna flip overMorph wrote:Then of course is the whole test flight thing. Quite nerve racking but a wonderfull achievement if it flies true hands off
