New Skyranger being assembled in East London....
FAWGie
Postby FAWGie » Wed Aug 09, 2006 10:20 pm
FAWGie wrote:
Bennie Vorster wrote:FAWGie
Moolas, how mutsh moolas for a kid like that?
Ready to fly with basic avionics, radio and 582 64HP Rotax, under R200k.....
The prices have been updated....take a look....
http://www.electrodynamics.co.za/skyranger/prices.html
FAWGie
Postby FAWGie » Mon Aug 14, 2006 2:33 pm
My opinion on what combination to buy for a skyranger.....
http://www.electrodynamics.co.za/skyranger/kits.html
Ian
Postby Ian » Mon Aug 14, 2006 3:22 pm
FAWGie wrote:My opinion on what combination to buy for a skyranger.....
Nice and competitive !
One point, would you need the CHT probes on the 582 option ? Perhaps EGT and gauge :?:
Cheers ian
FAWGie
Postby FAWGie » Mon Aug 14, 2006 3:29 pm
Cheers ian
Good point you raise.....My reason for not suggesting the EGT's is that that you have absolutely no control over the mixture, so it serves no ,ore purpose than to tell you if the carb is working correctly. I prefer the CHT guage as the motor is working quite hard (being in the lower HP range) and although you are monitoring water temperature, the CHT will show up disparity if the cylinder temps differ, pointing to a potential seisure.....
Minimal config could actually get by with only the water temp guage......
For a couple of extra bucks, stick in both CHT and EGT...the panel looks far prettier... :wink:
Ian
Postby Ian » Mon Aug 14, 2006 3:36 pm
I fly with a 582 now, and the norm for basic engine monitoring is water temp, where the sensor sits on top of the 2 cylinders.
I fitted EGT and am amazed that it is not manadatory, saved my butt a few times and increased my range by always having correctly set carbs.. Also great when pressure changes (either flying location changes or hot,dry day).
FAWGie
Postby FAWGie » Mon Aug 14, 2006 3:38 pm
Ian wrote:I fly with a 582 now, and the norm for basic engine monitoring is water temp, where the sensor sits on top of the 2 cylinders.
You are right.....I found this link which talks about the usefulness of EGT's...I stand corrected....:?
http://www.ultralightnews.com/enginemai ... gauge.html
An exhaust gas temperature gauge can show you whether your engine combustion chamber is running to hot or cold, lean or rich. It can also indicate problems with the engine.
For example:
-if your intake manifold were to develop a crack this could cause a lean fuel mixture, which would result in a higher EGT on that side.
-if the needle in the throat of the carb were to wear and drop down a notch this would show up on your EGT.
-if your gas to oil mixture was wrong it would show up quickly on the EGT.
-if something was wrong with your ignition system, a bad spark plug or faulty ignition cap/coil/wire this would show up as a colder EGT reading, since the fuel isn't being burned properly.
-if your prop is not set correctly it will show up in your EGT temps
-if a problem develops in one carb due too much or too little fuel this will show up in the EGT prior to take off it is very important that the engine be brought up to operating temperature, 1000 to 1200 degrees F you use EGT gauges to do this.
The proper EGT reading for all two stroke Rotax engines is 1,000 to 1,200 degrees F.
Ian
Postby Ian » Mon Aug 14, 2006 3:47 pm
Yep,
And with a 582 you can raise or lower the needle a few notches.. So there is 'some' adjustment even though the requirement is to change jets when operating out of different gnd levels...
TouchNgo
Postby TouchNgo » Thu Aug 31, 2006 2:50 pm
Hey Fawgie,
how about some more pictures of the progress :D :D
Greg
Jln090262
Postby Jln090262 » Tue Jul 24, 2007 9:23 pm
Wys ons hoe lyk sy nou
Captain Biggles
Postby Captain Biggles » Wed Aug 15, 2007 8:22 am
Hey girls and Boys,
Recently a friend went for a flip in the School's skyranger (64hp rattex) and posted this clip on you tube....take a look...
http://www.youtube.com/watch?v=3p6l7eJz ... ed&search=#
The demo pilot was Fawgie.....and the pax is Graham Mac.....
