Vhf radio air//marine
SoLo
Re: Vhf radio air//marine
Postby SoLo » Fri Feb 15, 2013 1:55 pm
Marine TX/RX
Airband RX only
No 29Mhz
Witkop
Postby Witkop » Fri Feb 15, 2013 2:13 pm
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return.
ZU-DAT
Witkop
Postby Witkop » Fri Feb 15, 2013 2:36 pm
ZU-DAT
ZULU1
Postby ZULU1 » Mon Feb 18, 2013 9:04 am
I have checked my vx7r and is receives perfectly on air band and does transmit a few metres but is perfect on other bands especially the 136-174 band and also the low band and alao the uhf and pmr bands. It is opened up with a software reset. The vxa 710 receives on the commercial bands but the previous vxa 700 receives on the 136-174 band also. They are obsolete though. ...This is radio ham territory now..The vx 8r is even more complicated but i can lend this vx7r to you if you wish? Its name is come back though.
Postby Tumbleweed » Mon Feb 18, 2013 2:01 pm
Paul, doesn't the Vertex 710 I got from you have this feature?
Witkop
Postby Witkop » Mon Feb 18, 2013 2:45 pm
Thanks Paul
Can a "air radio" be opened up to talk and receive on the 29mhz frequency?
ZU-DAT
ZULU1
Postby ZULU1 » Mon Feb 18, 2013 2:47 pm
Unfortunately not..well if somebody had the time...hard work. Yes Leon, it does..
Witkop
Postby Witkop » Mon Feb 18, 2013 2:54 pm
Do you have a vx7r to sell paul?
ZU-DAT
Witkop
Postby Witkop » Thu Feb 21, 2013 12:57 pm
Does any body know this radio AR-108 Maycom Receiver AM/FM/Air? Will it work ?
ZU-DAT
SoLo
Postby SoLo » Thu Feb 21, 2013 1:10 pm
It will receive Airband and VHF 137-180 MHz
No TX - Rx only
Witkop
Postby Witkop » Thu Feb 21, 2013 1:57 pm
ZU-DAT
Witkop
Postby Witkop » Sat Feb 23, 2013 4:25 pm
I think i found the radio!
The IC -80ad vhf/uhf Wideband receiver
The IC-80AD has a wideband receiver as a standard feature and covers 0.495-999.99MHz. *Listen to aviation, marine, weather channels and other utility communications*.
*Receiver range depending on versions. See specifications page.
I know this sounds to good so i hope zulu can give some advise on this radio
ZU-DAT
Peter.L.
Postby Peter.L. » Mon Mar 04, 2013 7:30 pm
Hi Guys,
This is not the sort of topic which should be discussed on an open forum, in fact in terms of the current legislation, it is not a topic for discussion anywhere, except maybe between friends on a face to face basis. Just remember that if I can read this forum, so can others who may not be as tolerant as me. Also remember that an illegal piece of radio equipment can only be made legal by being type-approved for a particular function, or for operation on a particular segment of the frequency spectrum. Some equipment can never be type-approved ito our current legislation, e.g. scanners operating above 30 MHz. Additionally, even if a radio is type-approved for use in SA, the moment you modify it the type-approval becomes invalid and it has to be re-tested before it may legally be used or licensed in its modified form. No radio operating on the air band and marine band has ever been type-approved for use in RSA (or in most other countries) and given the current state of technology, it is extremely unlikely that one ever would be.
Please accept this posting in the spirit it is written and be a little more careful of what you discuss openly, paticularly when it involves modifications.
Regards to all,
Peter
ZULU1
Postby ZULU1 » Mon Mar 04, 2013 8:03 pm
I agree with this statement, can we delete this thread, certain equipment in the wrong hands can cause total chaos. Similar to a Arduino project used as a drone controller...
