Zu-DSR's Engine problems (was ZU-DSR first engen out)
Bennie Vorster
Re: ENGIN
Postby Bennie Vorster » Mon Jun 25, 2007 8:56 am
Quentin Ferreira wrote:HI BENNIE
Moet se die engin klink baie mooi......het vanogend bietjie gekyk met die flyby........Lyk en klink stunning!!! So verkoop hom nou aan my...... :lol: :lol: :lol:
Quentin Ferreira
ZU-ATP
Newcastle
Wag net dat ek eers seker maak dat hy 110% reg is en ek my lisensie gedoen het, dan kan ek vir my 'n Zodiac kit kry om te bou. :wink: :wink: :wink:
Bennie Vorster
083 277 5110
Quentin Ferreira
Training
Postby Quentin Ferreira » Mon Jun 25, 2007 11:07 am
En hoe gaan dit met die training hoeveel ure al???
Quentin Ferreira
ZU-ATP
Newcastle
Bennie Vorster
Re: Training
Postby Bennie Vorster » Mon Jun 25, 2007 11:49 am
Quentin Ferreira wrote:En hoe gaan dit met die training hoeveel ure al???
Quentin Ferreira
ZU-ATP
Newcastle
:? Nog net een uur gedoen. Die wind het ons vanoggend uitgehaal vir 'n ses. :roll: Sal maar sien wat gebeur die week vorentoe. :wink:
Bennie Vorster
083 277 5110
Quentin Ferreira
Postby Quentin Ferreira » Fri Jul 13, 2007 9:01 am
Nou sien jy wat vorentoe gebuer het jy het hom aan my verkoop!!!!!!!!!!!!! :D :D :D
Quentin Ferreira
ZU-ATP
Newcastle
Bennie Vorster
Postby Bennie Vorster » Wed Jul 25, 2007 10:50 pm
:shock: ZU DSR is going for 20 hours since the motor has been redone. :shock:
I must admit that I was forced to catch up on some tips and secrets on these VW motors.
For example: You will never believe how munch problems you can encounter if you do not have the correct prop and reduction drive fitted.
I just swapped the prop last week from a 72/50 to a 72/52 and revs came down on the cruise by between 400 rpm to 600 rpm and with full throttle it came down from 4500 rpm to 3800 rpm. This in turn meant that my motor is not working itself to the bone = less sump compression and no more oil spilling. Also lighter on fuel, also 15 mph faster and is now cruising at 80% power between 90 and 95 mph. :wink:
Also were the stick was pulling to the front all the time, it is now back to a hands off neutral flying position for strait and level and even the flapperons is now been used in the manner it was created for.
Slowly but surely all the teething problems gets to be sorted and you guys can be soooooooo sorry you did not bought it when she was up for sale.
My landings is also coming on quite well now and I did about 8 hours towards my BB Conversion now. :wink: :wink: :wink:
Bennie Vorster
083 277 5110
Postby Morph » Thu Jul 26, 2007 9:59 am
Bennie,
this is indeed good news
Barnstormer
Postby Barnstormer » Thu Jul 26, 2007 1:02 pm
Mooi man Bennie!
Ek is bly jy is besig om die VW uit te sorteer!
Hoe lyk dit? Wanneer kry jy nou vir jou 'n smart diesel? Die VW gaan jou nou net begin verveel en ons gaan nie meer by jou kan leer nie! :D
Planeless...
Quentin Ferreira
Postby Quentin Ferreira » Thu Jul 26, 2007 1:22 pm
Bennie when is the SOLO PARTY????????
Quentin Ferreira
ZU-ATP
Newcastle
CloudDancer
Postby CloudDancer » Sat Aug 04, 2007 7:52 am
I see the engine is open again???
GR8-DAD
Postby GR8-DAD » Sat Aug 04, 2007 8:29 am
CloudDancer wrote:I see the engine is open again???
...one hour too much..... :? :?
Wat gaan aan Bennie?
S 32°16'49.8 E 18°53'33.0
Bennie Vorster
Postby Bennie Vorster » Sat Aug 04, 2007 6:42 pm
Yip it is true. I have a problem with the valve gaps that keep on closing, causing the valves not to close as they should. So the only thing I could think that can cause this is if the valves eat into the seats. :roll:
So I pulled the tops off but can not find any obvious reson for this strange phenomena. So I send the tops off to the engineering works to get redone and to fit double high performance valve springs.
Then checking the cam followers I found one to be a bit more sticky than the others so out came the motor to be split and to make sure all the inside components is still in spec. :wink:
Bennie Vorster
083 277 5110
John Young
Ay-yi-yi-yi-ya
Postby John Young » Sat Aug 04, 2007 7:19 pm
Bennie Vorster wrote:Yip it is true. I have a problem ...
Ay-yi-yi-yi-ya - Genoeg is genoeg :!: :shock: :shock: :shock: - hou moed Bennie :!:
Groete
John ZU-CIB
Quentin Ferreira
Postby Quentin Ferreira » Mon Aug 06, 2007 1:41 pm
Daar is 1 positiewe punt en dit is nou kan ons lekker saam trike vlieg!!
Quentin Ferreira
ZU-ATP
Newcastle
Bennie Vorster
Postby Bennie Vorster » Tue Aug 14, 2007 6:58 pm
Please I need your input on this Idea. I have a theorie for the cause of my problems and the solutions. I do not know if the solution is the answer though.
Please tell me what you think. We have cut open a normal as the man on the street know it, an old time mechanical cam follower and found a little surprise inside it.
Bennie Vorster
083 277 5110
Bennie Vorster
Postby Bennie Vorster » Mon Aug 27, 2007 3:40 pm
Ok I'm getting back on track and another R4200.00 later new valve springs fitted, a new set of cam followers fitted, heads redone completely and the motor is again been installed this morning.
I will fit the final nutty gritty and do the necessary tuning some ware threw the next week or two and then it is taking off time again.
-0< -0< -0<
At least I now have the most expensive VW motor I know of. ':-
Bennie Vorster
083 277 5110
