MEDICAL AT AIRFIELD
hugo_visser
MEDICAL AT AIRFIELD
Postby hugo_visser » Tue Nov 11, 2008 8:18 pm
Hi, we want to start a medical testing facility at Petit ( FARA ) in one off your offices between the hangers. You can fly in and do your medical and then fly back,mostly on saturdays. You do not have to wait in waiting rooms and battle in carparks. Any ideas or suggestions.
AndyG
Re: MEDICAL AT AIRFIELD
Postby AndyG » Tue Nov 11, 2008 9:50 pm
drop the finger test
Low Level
Postby Low Level » Wed Nov 12, 2008 8:28 am
leftseat wrote:drop the finger test
:lol: :lol: :lol:
Apparantly they're using two fingers now. :shock:
Lotsa guys want a second opinion. :)
Think it's a good idea - very central, but I think it's going to expand to a weekday or two as well.
ZU-CFW
Postby John Boucher » Wed Nov 12, 2008 8:57 am
Other tests include a blood test to check on kidney function, and a special blood test (PSA) to check for biochemical evidence of prostate cancer. PSA stands for prostate specific antigen, and is a substance from the prostate gland, which is present in the blood of all men. As men get older the amount that is in the blood slowly rises. In prostate cancer the PSA test usually shows a higher concentration in the blood than would be expected. If the test shows a normal result this is reassuring and if the result is high it is likely that your specialist will wish to embark on further tests and treatment. There is a level, which is just above the normal range, but not yet high, which might lead to your doctor repeating the test after a few months. In actuality, there is nothing as serious as this condition. But if you would want to analyze its roots, its just that there hasn’t been much of ejaculation and the channels leading to a clarity in the tubes get blocked, thanks to the lack of oxygen. Most couples with an active love life are less prone to problems of the prostrate, or so it has been observed.
There are other prelim options such as a PSA test & obviously much much more sex! (^^)
Postby Gyronaut » Wed Nov 12, 2008 9:42 am
Ldel, very funny! :lol:
Its when you look around and the Dr has both his hands on your shoulders .... :shock:
Terms like "your specialist will wish to embark" shouldn't be used (**)
I'm with Bad Nav, best rememdy is lots of sex! klaar. (^^)
Low Level
Postby Low Level » Wed Nov 12, 2008 3:52 pm
Gonna show the softness this one. :lol:
ZU-CFW
hugo_visser
Postby hugo_visser » Thu Nov 13, 2008 2:08 pm
We plan to start in Jan 2008, now it is for painting and cleaning ect.
Bennie Vorster
Postby Bennie Vorster » Thu Nov 13, 2008 7:55 pm
:shock: Only problem is if you don't make your medical you don't have a lift back home. :shock:
Other than that it is a brilliant idea. :wink:
Bennie Vorster
083 277 5110
hugo_visser
Postby hugo_visser » Sat Nov 15, 2008 1:09 pm
The medical you flew in with is valid till the end of that month.
Stephan van Tonder
Postby Stephan van Tonder » Mon Nov 17, 2008 6:45 pm
Hugo - i think you meant jan 2009 :wink:
Users browsing this forum: No registered users and 29 guests
