http://www.youtube.com/watch?v=XRCbkBfd ... ture=bz303
Did you see the brown spot on the seatChoppie wrote:I am not a hotshot stunt pilot, but I do know something about lift and weight and balance. This situation wold be damn marvelous if one wing gives that amount of control. Looking at the situation one would imagine full airelon deflection to counter the lift of the wing, almost full RPM if not full for the torque effect to assist, full rudder deflection, and a pilot with MASSIVE kahunjas.
Also for the aircraft to be able to land one would think extra torque or aileron deflection would be required.
So I find it hard to swallow.
http://www.youtube.com/watch?v=SsNIhBly ... re=relatedextra300s wrote:This was done with a RC simulator. But the exact same thing happend at a big RC comp a year ago where a 100cc (about 2m wingspan) aerobtic planes left wing panel flew off. The guy kept the plane in knife edge and landed it. Just before touch down you level the wings. He bent the landing gear and broke the prop off. But is was the save of the century. Video is still out there. Will see if I can track it down. Remember with rc the power to weight is so good one can hang a plane on its prop using only 50% power. Not easy but It can be done.
That is just frigging unrealextra300s wrote:Choppie - todays radio controlled aerobatic, 3D planes defies the laws of flight.
See this video. This is real! RC
see
http://uk.youtube.com/watch?v=ZaXMrFh3n7M
No, honestly, he said it's real .slysi wrote:That is just frigging unreal
extra300s wrote:See this video. This is real!
True, but the RC types have a power to weight ratio second to none and if you want to increase it even more, you can probably get away with it. The real macoy doesn't always have that luxury, and therefore gravity applies (somewhere). I have seen a couple of clips where RC's are doing things that makes my mouth hang open, so The laws of flight and gravity is pretty much ignored by these agile little toys.extra300s wrote:Choppie - todays radio controlled aerobatic, 3D planes defies the laws of flight.
