Prop Safety
Uncle Spud Murphy
I hate bird strikes
I hate bird strikes
Prop Safety
Postby Uncle Spud Murphy » Thu Jul 24, 2008 11:19 pm
Greetings all,
I am new too all this, but learning a lot from reading the forums.
Tell me something. Have been reading some of the ground accident comments and the softness has shown concern about being decapitated by the prop. Must admit, I wouldn't be too happy about that myself (**) Is it possible to fit a cage around the prop of a Trike? Just a thought from one who know's nothing, yet.
Alles van die beste (^^)
Uncle Spud Murphy
John Young
Re: Prop Safety
Postby John Young » Fri Jul 25, 2008 6:56 am
Uncle Spud Murphy wrote:Have been reading some of the ground accident comments and the softness has shown concern about being decapitated by the prop. Is it possible to fit a cage around the prop of a Trike?
Hi Uncle Spud,
Only necessary if your softness decides to climb off and fly on a broom next to you. vhpy vhpy vhpy
Otherwise, your training will be sufficient to protect both of you. !!!!
John ZU-sEXY
Re: Prop Safety
Postby Morph » Fri Jul 25, 2008 8:45 am
yes spinning prop is a scary dangerous thing. A few years ago a guy skydived from a trike. as he turned and jumped, his hand was chopped off by the prop. :shock:
He managed to land safely. C205 knows more about this
Also if ever you land out in the rural areas you will be swamped my local kids. Again you have to be so careful when you start up and taxi that they don't run into the prop
a cage would be nice, like the power paragliding guys wear
Wargames
Re: Prop Safety
Postby Wargames » Fri Jul 25, 2008 11:13 am
The only issue with the cage is the weight it adds to the trike. And then their is always the mod thing with caa :oops: :oops:
Low Level
Re: Prop Safety
Postby Low Level » Fri Jul 25, 2008 12:49 pm
Morph wrote:his had was chopped off by the prop
Morph is that head or hand ?? :shock:
Landed safely can mean he didn't land on somebody ........ :wink:
ZU-CFW
Re: Prop Safety
Postby Morph » Fri Jul 25, 2008 3:12 pm
hand
sorry typing quickly
Tobie
Re: Prop Safety
Postby Tobie » Fri Jul 25, 2008 3:26 pm
Wonder if cage will affect airflow and efficiency?
Playing Planes.
ZU-BCW / ZU-BOC
Aerotrike / Challenger
Biggles
Re: Prop Safety
Postby Biggles » Fri Jul 25, 2008 6:35 pm
I think the parasitic drag, the interference with the efficiency of the pop and the added weight will be huge penalties for a danger that only exists for a very short period on the ground. A danger managed with checks and procedures. In addition to this, a cage only addresses one danger associated with run away props... i refer to the unfortunate gent who took off with the bar still tied to the profile tube and struck a building. A run away aircraft is a danger not only the prop.
Could an instructor post a start-up procedure?
I realise that my hand crank procedure is inadequate should there be a runaway engine situation. Firstly i have done this with a passenger already strapped in. Secondly standing by the side of the aircraft you do not have quick access to the mags. I do stand with my legs in-front of the rear wheel struts, to catch the aerie if it starts rolling forward given that the brake is inadequate. But should the engine rev up to full power I am sure I will be knocked over. Placing bricks under wheels will not stop a full throttle aerie either. The only solution seems to be a fool proof throttle system.
Something that forms part of the pref-light check is very important to prevent run away engine is pulling and releasing the foot throttle and confirming a audible click from the carbs signalling the throttles are free and returned to close. Even if one throttle stays open it will not runaway in that situation.
Trike pilot
ZU-DLP
Winelands FAWN
gertcoetzee
Re: Prop Safety
Postby gertcoetzee » Fri Jul 25, 2008 6:51 pm
When I am about to start up, I show the kids a handfull of R2s and R5s and tell them I am going to drop it over there. They take off for the spot and I take off without creating kid carpaccio.
Dre'man55
Re: Prop Safety
Postby Dre'man55 » Fri Jul 25, 2008 7:34 pm
An option is a cut out that we use on the quads, jet ski's and boats. You strap it to yourself and if you move away from the vehicle it will cut the ignition. The cord is coiled so allows for a fair amount of movement.
Must get airborne again
Andre'
Flying Below power lines on a DSX650
Too much power is just enough
Re: Prop Safety
Postby Morph » Sat Jul 26, 2008 4:43 pm
Sounds like a good idea for the runway plane problem, especially if you have to hand start it
Just dont want it cutting out in the air with the wind blowing the thing out etc
Dre'man55
Re: Prop Safety
Postby Dre'man55 » Sun Jul 27, 2008 8:55 am
Morph wrote:Sounds like a good idea for the runway plane problem, especially if you have to hand start it
Won't blow out in the wind, it takes a solid tug. But if attached to the pilot will not allow him to move more that 1- 1-5 m away from the aircraft.
Andre'
Arnulf
Re: Prop Safety
Postby Arnulf » Mon Jul 28, 2008 2:14 pm
Dre'man55 wrote:An option is a cut out that we use on the quads, jet ski's and boats. You strap it to yourself and if you move away from the vehicle it will cut the ignition. The cord is coiled so allows for a fair amount of movement.
This is probably the best idea to alleviate the run away problem with rope start trikes.
Well worth investigating.
Re: Prop Safety
Postby Tailspin » Mon Jul 28, 2008 2:28 pm
I was looking into that but there are certain problems that could be NASTY.
Some people will tie it to the main tube under the seat and never use it - the Human factor is allways a big question (**)
I prefer the Idea of making the pull starter longer and then routing it to a point that it is reachable from the Front seat ! ?!
powerfly
Re: Prop Safety
Postby powerfly » Tue Jul 29, 2008 8:11 pm
The pilot who let the skydiver jump out without stopping the engine is responsible for the parachuter. Stupid for not switching off.
Noel McDonogh
World of Wings Flight School
Umkomaas Airfield
info@wowflight.co.za
0721175130
