ROTAX 618
ZU-CDW - Shark
ROTAX 618
Postby ZU-CDW - Shark » Thu Dec 06, 2007 11:39 am
Can anyone please give me some advise on the Rotax 618. Is this a reliable engine to be used on a trike and can it be utilised without the exhaust reed valves. Compared to the 582?
Where can I obtain manuals etc
Shark
0833036044
ZU-CDW
Postby John Boucher » Thu Dec 06, 2007 11:41 am
Have a chat with Morph.....
Postby Morph » Thu Dec 06, 2007 11:54 am
I know of two running in Cape Town, albeit in Fixed wing aircraft. They appear to be reliable and they perform better than a 912UL due to their lighter weight.
I don't have an answer on the reed valve story
Here is a lot of information including all of the manuals
http://www.ultralightnews.ca/rotax618
Henni
Postby Henni » Thu Dec 06, 2007 12:03 pm
I think Rudix also has one installed in his Rans-S12 & he flies ALOT. See where his Rans is headed for shortly & he does these sort of things often.
viewtopic.php?t=6039
Henni
Rudix
Re: ROTAX 618
Postby Rudix » Thu Dec 06, 2007 12:58 pm
ZU-CDW - Shark wrote:Can anyone please give me some advise on the Rotax 618. Is this a reliable engine to be used on a trike and can it be utilised without the exhaust reed valves. Compared to the 582?
Hi Shark,
Yes, it is a great engine, like Morph said performance is better than a 912 due to a better power to weight.
I have one in the Rans, currently on about 450 hours, and did my training in a X-Air with a 618, that one had more than 700 hours if I remember correctly.
They do like to rev, so don't lug them down to much. You can use them without the exhaust valves, there is a override option (I am not using it) or you can remove them, the one in the X-Air had them removed. Without the valves you loose a bit of power but it is still more powerful than a 582.
I hope this helps !
Fly safe,
ZU-CDW - Shark
Rotax 618
Postby ZU-CDW - Shark » Thu Dec 06, 2007 6:45 pm
Thanks to you all for the replies and info
Shark
0833036044
ZU-CDW
Postby Duck Rogers » Thu Dec 06, 2007 11:09 pm
It's not advisable to remove the valves. If you're at altitude (Gauteng) just open them fully and fix them in that position.
Smiley
Postby Smiley » Fri Dec 07, 2007 8:13 am
One of my friends at Springs has a 618 on his trike, and seems to be flying without a hitch...! :wink: :wink:
But, I've heard a very prominent pilot say that the 618 was the most unreliable motor Rotax has ever produced.. :shock: :shock:
ZS-WGT
Springs 122.40
Aerosan
Postby Aerosan » Fri Dec 07, 2007 3:24 pm
Ill buy one tomorrow if I can find one.................and I mean that. 8)
Postby Morph » Fri Dec 07, 2007 3:31 pm
Smiley wrote:But, I've heard a very prominent pilot say that the 618 was the most unreliable motor Rotax has ever produced.. :shock: :shock:
it appears that the 618 due to it's better power to weight ratio (thus performance) compared to a 912ul, plus it obviously being far cheaper, was seriously impacting on the sales of the 912. So Rotax pulled it off the market. As a result no further development on the motor. I suspect the rumours were conveniently spread to further kill the sales. (conspiricy theory #5644766761) I have not heard of a single issue with these motors from any of their owners.
The only concern I would have is availability of spares
Postby John Boucher » Sat Dec 08, 2007 12:21 am
If Rotax brought back the 618 again, the 582 would disappear.... instead of the 300hour TBO it boasts with a 600hour TBO! Correct me if I'm wrong.... :)
Smiley
Postby Smiley » Thu Dec 13, 2007 9:21 am
:wink: :wink: :wink:
ZS-WGT
Springs 122.40
