Buying your self an aerie????
Bennie Vorster
Postby Bennie Vorster » Fri May 04, 2007 8:47 pm
:shock: Take note: :shock:
10 point ultralight or light sport aircraft buyers guide.
Selecting an ultralight Part 1
Many pilots, aviation enthusiasts are looking at ultralight aircraft or light sport aircraft, as either an entry level craft, or as just a more affordable alternative to general aviation due to the steadily increasing cost.
One of the major problems facing this group is in selecting just what craft they should buy.
Questions include whether it should be new or used, on floats or an amphibian, the kind of engine and horsepower, should the craft be enclosed, partially enclosed, or fully enclosed.
Also, consideration must be given to speed and range. Once you have decided what kind of a craft will fit the bill, the most important consideration is convincing the wife on how much money you can spend!
If you use this article correctly, it will prevent a great deal of headaches down the road and should save you money when purchasing your craft. The least it will do is prevent you from becoming a "test pilot".
The following is a simple ten point program that can be used for either new or used aircraft. In my mind a passing score is 70% or over, to completely fail would be 50% or under.
1.The number of years the factory has been building planes: The longer the better, 5 years gets you 10 points anything less is 2 points less for each year.
Why must the manufacturer be in business for at least 5 years?
Here is an example. In 1984 a new factory shows up with a brand new aircraft at a show. The craft on display is the original prototype with about 20 hours of flight time on it. The plane is well received and nearly 30 orders are taken. The show is in April, first deliveries are about 4 months later. The craft in question takes about 250 hours to build for first time builders. The normal builder can spend about 5 hours a week on average building his plane. 5 into 250 is 50 weeks, meaning his craft is ready to fly approximately 1 year after receipt of kit, which was 4 months after placing his order. The kit is ready to fly in August of 1985. Now the pilot begins to fly his craft. Like anything new some problems are encountered. The average pilot flies about 50 hours a year, and lets say his problems start at this time. The year is now 1986. These problems are reported to the factory. The factory looks at the problems and begins changing the design of the aircraft. In most cases they already have material designed for the older style of craft, which they use to prepare any remaining kit orders.
The pilot checks to see what other updates the factory has put out. To his amazement there are 22 updates to his craft. After pricing the updates he calculates the cost at about $2,800. His craft is worth about $4,000 on the open market, and a new plane sells for $6,200 in kit form rather than update he decides he is better to sell and buy a new kit.
Who is he going to sell his aircraft to....... My recommendation is if you are buying used buy an aircraft that has been in production for at least 3 years. example: If the first kit produced was in 1985- buy a 1988 or later model.
2 points off for every year less than 5 that the manufacturer has been in business.
2. The number of planes that have been sold, and the number of planes that are actually out there flying:
It is fine to sell 1,000 aircraft kits, but if it takes 500/1,000 hours to build a kit then it will be some time before those kits are actually flying and problems associated with their use are reported back to the factory, for correction.
Most of the factories that I have had dealings with over the years are selling at least 10 kits a month. This means that if they have been in business for 5 years they have produced a minimum of 5 x 12 x 10 = 600 aircraft. 600 aircraft flying generally means that even if the manufacturer goes out of business it is would be economically feasible for other manufacturers to produce parts and pieces (sails/tubing/brackets) for this aircraft.
10 points for 100 kits sold.
If the manufacturer has not sold 100 kits delete 2 points for every 10 below 100.
Many quick build kits such as the Quicksilver MX are ideal aircraft for this kind of chart. The kit takes about 50 hours to build, sometimes in a little as a week the owners had their craft flying. Because of this they would be flying very quickly resulting in problems being reported to the factory. With the marketing used by Eipper it was reported that in a 4 year span some 10-12,000 kits were delivered world wide.
3. 10 points for 100 aircraft flying. Delete 2 points for every 10 below 100.
4. Control system :
3 axis standard control gets you 10 points
weight shift in a trike gets you 10 points
2 axis control gets you 5 points*
weight shift control other than trike gets 2 points
Standard three axis control systems get 10 points as do trikes because they allow flight in more varied conditions, during more hours of the day. They also give the pilot cross country capability because he knows that he can land in a cross wind at another field.
Two axis control only receives 5 points due to the crafts limitation in cross wind, and windy conditions. Most two axis control aircraft will be flown in early morning or late evening conditions, and usually just around the take off and landing site.
*I give this type of craft 10 points if the owner is buying the craft to fly in these conditions. I know of many pilots who own two axis control aircraft on floats, who fly only morning/evenings or on weekends from the lake where their cottages are located.
5. Engine: Rotax engine gets you 10 points. Any engine that is still in production gets you 8 points, Cuyuna, Kawasaki 6 points.
I give Rotax a 10 because they have engines from 28 to 79 horsepower which can be bought as a complete package, including carb, exhaust, and cooling systems. Have a worldwide service network, which is factory trained. Rotax itself is not a small company and produces nearly 80 per cent of the engines used in light recreational aircraft.
Hirth engines fall short in some of the areas mentioned above but still should receive an (8). Cuyuna was one of the mainstays in the industry, parts are available. The only problem with the Cuyuna was that it was either a good reliable engine, or it made a great boat anchor. (8)
Kawasaki was another engine that was widely used. Unfortunately it is harder to get parts and pieces for it, and it generally wasn't sold as a complete package meaning that the exhaust and carbs in many cases were not matched to the engine.(8)
6. Two place trainer: If the company produces a two place trainer then the plane gets a 10. It is great to be able to buy a plane when you can be trained in the same model in a two place.
While some of the climb rates and speeds may be different between he single and two place, the basic flying of the two craft is very similar. Having flown/and taught students to fly in the Challenger, Kolb, Buccaneer, Rans Coyote, Airaile, Quicksilver MX and MXL, Carrera in both the single and two place versions I can vouch for the fact that these craft fly very similar.
If the company does not produce a two place trainer, but your local dealer, or instructor has flown the craft and indicates that its flight characteristics are similar to the craft you are training in give it a 10.
If no information on the flight characteristics are readily available, from a knowledgeable source, then I would first grade the aircraft minus this category (90 points instead of 100), and then if it passes the other categories give it the per centage that it passed by e.g. 60 % = 6 points, and then recalculate.
7. Cross country capabilities: If the plane has good cross country capabilities 50 to 55 mph cruise then you get another 10 points. Once again if the craft has been purchased for the sole purpose of flying "around the patch" at 25 to 35 mph you can still give it a 10. However if it is three axis control and capable of 50 to 55 mph in cruise it means that more use can be made of the craft flying to flyins and other pilots fields. It also is less bothersome to neighbors, since you are not buzzing away in their ears for extended periods of time.
2 Points off for ever 5 MPH cruise below 55.
8. Dealer: If there is dealer within 100 miles give the plane a 10. Many factories sell direct. Unfortunately this means that you have no dealer support, for training, or parts and pieces. In some cases it means that you might not have a place close by to fly from with other pilots. Many dealers have engine specialist on staff with many hours of trouble shooting experience. Also a dealer can teach you how to fly. These problems are generally not part of the factory support package.
2 points off for every 10 miles from dealer.
If you have to buy direct from the factory, but a dealer near you stocks parts and pieces and offers training 8 points
9. Planes in the area: If there are a lot of that plane flying in the area, or you can talk to more than 5 owners who fly a lot then give it a 10. 2 points off for each pilot less than 5. I have never heard a mother say that her child is ugly! You are not very likely to hear a factory or a dealer tell you about the problems with their aircraft. The more people you can talk to the more feedback, both positive and negative you will receive. Better to make you own judgment.
10. Safety Record: What is the planes overall safety record in the years it has been produced? If the type of craft you are considering has no unexplained accidents give it a 10. If there seem to be several accidents with no apparent cause I would be a little nervous.
DO NOT, I repeat DO NOT get this information by word of mouth from a dealer. Get the facts from pilots, publications or government agencies.
If I were just entering the ultralight market the area of this chart that I would be most concerned about is number
8. The local dealer, and his customers. If there is a dealer near you, who has been able to survive the roller coaster ride that this industry has gone through, then he/his customers should be able to supply to with information on the industry and the craft you are considering. He can also supply you with parts, service, and a flying site. In my mind a craft without a dealer is like a one parent family. A mother and father (manufacturer & dealer) can supply a child (aircraft) the necessary care and attention that one may not be able to provide.
This is part one in a two part series. The second part will be dealing with used ultralights and things that you should look at on the aircraft, prior to buying. Basically it is a used aircraft buyers guide and will deal with many of the major brands of used aircraft, including those that are no longer in production. It will also list problem areas, parts suppliers, and give an approximate value of an aircraft in Good condition/Fair condition/and the area in between.
Using part one and two together should ensure that you get the safest most cost efficient craft for your buck.
Ultralight aircraft buying tips, how to buy a used not abused ultralight.
Evaluating a used ultralight aircraft.
At Oshkosh 92, as the crowd stood in awe, the pilot of a foot launched Easy Riser, powered by a little 2 cycle engine, lifted his craft onto his shoulders and launched it into the air. In 1978 this launch would have cost the pilot about $1200.
One of the things that has been common throughout Ultralight aviation history is that costs have been going up! Some of today's ultralights reach prices over $60,000 when ready to fly! Why? The days of producing ultralight aircraft for the MASSES, have ended.
Most manufacturers are now building specialized aircraft to fit target groups. While this may cut down on market share, it allows increased profit margins. Selling and producing one aircraft at $40,000 with a 25% profit margin is more profitable than selling and producing 8, $5,000 aircraft at an even lower profit margin (remember the average new engine sells for around $5,000).
Canada with a population of 28,000,000 has approximately 4,000 registered ultralights (our aircraft are registered, and our pilots licensed). The United States, has roughly 280,000,000 people assuming the same percentage of people own ultralights then that would mean 40,000 ultralights. Combine the Canadian and US market and you have 44,000 USED ultralight aircraft. Which ones are a better buy? How much are they worth? Which are the safest? Where do you get parts and pieces for them?
This is the second in a series of articles dealing with purchasing an ultralight. The first in the series was a 10 point system used to evaluate an ultralight, new or used. Next in the series will be a Buyers Guide of used aircraft, with information on where to get parts and pieces and the estimated value of certain craft.
Now let's look at areas to examine when buying a USED ultralight. In order for any aircraft to get into the air and back down again you require, an airframe, a propulsion system, a control system, landing gear, a wing assembly.
Lets take a look at these:
Airframe Propulsion Landing Gear Rotax Gear Drive Belt Drive Control System
Exhaust Reduction Drive Wing Assembly Parachutes Propeller Planetary Systems
Airframe: This is the basic structure of the craft, the center section or the area the pilot sits in. Found in the airframe (in conventional ultralights) are: the joystick, rudder pedals, rudder cables, throttles, throttle cables, usually the fuel tank. It is also the area of the craft that the landing gear, wing struts and tail surfaces connect to.
Propulsion system: Powers the craft, engine, exhaust system, carburetor, fuel pump, reduction drive, and propeller make up the propulsion system.
Control system: This is what controls the craft, usually a joystick and rudder pedals, connected to the ailerons, elevator(s), and rudder(s).
Landing gear: These are the parts of the aircraft that contact mother earth during taxiing, take off and landing. It is the area that must "take a licking and keep on ticking."
Index
Wing assembly: The parts that make up the wing, and connect it to the airframe.
These parts together make up the aircraft. In many ways they are similar to the parts making up the human body, and like the human body, with age, neglect, and lack of proper care and feeding, things once done all night, now take all night to do, or can't be done.
The advantage that an ultralight has over the human body is it consists of replaceable parts. The disadvantage is that when you are buying it, the seller may stretch the truth a little by forgetting to mention that the little old lady that flew it "only to church on Sundays," was 200 miles from that church. That the only field she had to land on was plowed, and that several time on take-off she clipped the top off several trees. Since ultralights do not require engine or airframe logs, it is very hard to disprove the actual hours of use an ultralight has on it.
When negotiating the price of a car, you would take tire wear, paint and interior condition, dents, rust, etc. into consideration. You should do the same when buying an ultralight. Let's look at these areas in a more detailed way.
Airframe: This is really the main frame of your aircraft sort of like your skeleton minus feet, arms, hands. Connected to it is the landing gear (feet) and wings (arms). All the control systems (muscles, nerves) usually run along or inside it.
While many other parts are replaceable, you are not likely to replace the fuselage. For this reason it is important to check it for signs of wear. Wear will be most evident in areas of the fuselage that connect to the landing gear, or a moving part like the steerable nose wheel, or engine attachment points.
Look for bent or cracked tubing , tubing with elongated holes , tubing worn from metal on metal contact . If your aircraft is riveted together examine the rivets at areas of the craft that might flex, or is subject to vibration . If you are buying an aircraft that features an enclosed cockpit look very carefully on the floor of the enclosure, under the seat or gas tank, (this is an area that is difficult to clean) for signs of rivet heads. This could indicate recent repair or a hard landing.
Check the area where the landing gear passes through the fuselage for cracking or damage. Check the area of the fuselage where the rudder attaches to the vertical fin for cracks . Check the area where the pilot's enclosure or hull contacts the airframe for wear . Check nuts and bolts for bending .
Many older designs used pit pins. These are no longer used! These corrode, are weaker than an AN nut and bolt, resulting in failure under load . If the aircraft you are looking has pit pins you should deduct the cost of replacing them with AN nuts and bolts from the cost of the plane.
Check the engine mount for cracks.
Check the rubber mounts for cracks, failure, or UV deterioration .
Check plastic saddles for signs of failure
Check bolts securing struts to wing on early model wire braced aircraft for failure of the securing bolts.
Check cable ends for signs of stretching .
Check all cables where they may contact metal for fraying .
Approximate cost of replacement parts.
AN bolts $ .25 - $7.00 (each)
AN nuts $ .40
Lord mounts A $ 3.00
Lord mounts B $ 8.15
Lord mounts C $ 8.75
Engine mount $ 75. - $ 500.
Plastic saddles $ 1.- $ 2.
Wing bolt update kit $ 79. - $ 99.
Index
Propulsion system : The propulsion system consists of -- Fuel system, exhaust system, reduction drive, engine, and prop.
Fuel system : Many ultralights come up for resale because the owner has medical, financial or family problems (or has simply lost interest.) The decision to sell usually does not come easily. This can mean that the aircraft has been used sparingly, and has been tied down, out in the open at a flying field, at the mercy of the elements, or hangared for long periods of time. If the reason for the sale is financial, aircraft maintenance should be of prime concern!
In many cases the aircraft is left with fuel in the gas tank, and carburetor. Pull the cap off the gas tank, or the bowl of the carburetor you will know immediately whether the plane has been in storage. The smell will knock you off your feet! Adding fuel, or starting the engine without first draining and cleaning the complete fuel system can severely damage the engine, your body or the aircraft, when the engine quits from a clogged fuel system during takeoff! Consider the cost in time, and parts necessary to bring the fuel system back to 100%, when buying an ultralight.
Recommended replacement parts: The fuel shut off valve, fuel filter, fuel line , primer lines, rubber intake manifold(s) , primer bulb, carburetor bowl gasket(s) main jet and idler jet , and gas tank grommets . With storage, gas and UV deterioration will make it necessary for most if not all of these to be replaced or cleaned. If the engine has a sponge air filter, replace it with a K & N air filter.
Many older ultralights came equipped with 503 Rotax or Hirth engines using a single Mikuni fuel pump. Both single and dual carb 503 Rotax/Hirth engines should use the dual Mikuni fuel pump . The pump should be; rubber mounted, a maximum of 12 inches, from the vacuum source on the engine, away from heat, and with the vent on the pump, (found in the middle of the vacuum elbow) facing down.
Another common problem on aircraft equipped with either the Mikuni or Bing carburetor was wear in the needle valve and or retaining clip. This wear would cause the needle to fall down into the carburetor resulting in the engine dropping back to an idle .
Approximate prices:
Fuel shut off $ 7. - $ 10. (each)
Fuel filter $ 3. - $ 5.
Carb bowl gasket $ 5.
Squeeze Bulb primer $ 6.
Gas tank grommets $ 1.
Dual pump $ 29.50 - $ 80.
Air filters $ 20. - $ 35.
Primer line $ 1. per ft
Fuel line $ 25. for 25 feet
Impulse line $ 1. per ft.
Jet needle $ 6.00
Jet needle clip $ 3.00
Main jet $ 4.50
Idler jet $ 14.50 (each)
Index
Exhaust System: The exhaust system on a two stroke engine plays a very important role in the life and performance of the engine. When buying an ultralight look for cracks, in the exhaust system, or recent welds, which would indicate someone has repaired the exhaust or modified it. Either is cause for concern! Repair work would indicate; improper exhaust mounting, modifications can result in engine overheating, loss of performance, and or engine failure . Other areas of concern are the rubber mounts used to support the exhaust system. Check them closely for separation, cracks, or other damage .
Approximate replacement costs:
Rotax exhaust $ 500.00 approximate
Cuyuna Exhaust $ 200.00
Rubber exhaust mounts $ 3.50 (each)
Exhaust springs $ 6.00 (each)
Rubber exhaust mounts $ 9.50 (each)
Exhaust mounting kit $ 89.95
Reduction drive: The first type of drive used on ultralights was direct drive. This means that the propeller bolts directly to the crankshaft. Engines that used this type of drive were the JPX, Rotax 9.5, Pioneer Chainsaw, Koenig, Chrysler West Bend, Mac 101, Global and some early model Cuyuna engines.
The load exerted by the propeller, on the crankshaft, during changes in aircraft attitude, and speed, are very extreme. This has resulted in reports of crankshaft failure, on most of these engines . If you are considering buying a craft that uses a direct drive system grab the output shaft and see if it will move up and down, an indication of imminent failure. Look at the casings, where the output shaft exits the engine. Hairline cracks seen in this area may also indicate crankshaft failure.
Ed. note - Many thousands of safe flying hours have been logged by pilots of Lazair's, Mitchell Wings, N-3 Pups and Gold wings using this kind of system.
Approximate replacement cost:
JPX crankshaft $800.00
Rotax 9.5 crankshaft $650.00 (plus additional parts and labour)
Index
Belt drive systems:. This was the second type of system used in ultralights. These drives used an upper and lower pulley, of different diameters, and a single or series of belts, to reduce the prop RPM. This allows the use larger propellers for better performance and reduced noise. When buying a craft equipped with a belt drive system check out the two pulleys for wear or damage, the condition of the belts, shaft bearings wear . Also check the reduction drive casings for signs of cracks or damage . Early model Quicksilver MX aircraft used a coupler to connect the driveshaft to the engine. This coupler failed and was updated to a large diameter coupler ).
Many early designs used belt drive systems on the Rotax engines. On early model 277 engines over tightening the drive belt can result in failure of a plastic liner used to support the crankshaft PTO end bearing. Failure has also been reported on 377/447/503 crankshafts using belt drive systems. If purchasing an aircraft with over 100 hours on it using a belt drive on a Rotax engine, a complete tear down and rebuild of the engine is recommended!
Planetary systems: Several planetary systems were used over the years on ultralight aircraft. Most are no longer available. One widely used system was the Winters reduction drive. Failure of this system forced the manufacturer to stop production. Failure has occurred at the output shaft, resulting in the propeller exiting the aircraft. Failure also occurs in the aluminum ring supporting gears inside the casing, usually resulting in seizure of the drive system, resulting in a forced landing.
Recommendation: If the craft you are considering, has this re drive system; DO NOT FLY until you change the drive system. Consult aircraft manufacturer or someone knowledgeable in the industry for advice.
Rotax gear drive: Updates have occurred to the Rotax A/B reduction drives.
The first was an update from 2 groups of four spring washers on the output shaft to 3 groups of 4 washers . Reason -- failure of the spring washers resulting in hard starting.
The output prop hub was also update from a two piece steel shaft/aluminum hub arrangement to a one piece steel shaft and hub. Reason -- failure of the aluminum hub, and stripping of the prop bolt retaining threads in the hub.
Another update was going from a 3 bolt gear box to engine adapter plate to a 4 bolt engine adapter plate. Reason - failure of the bolts holding the adapter plate to the engine, causing loss of drive, or damage to engine case. .
Vent cap update-Rotax has updated the vent cap on the gear drive to that shown here . This update helps prevent loss of gear drive oil due to siphoning action of the propeller, or gear drive internal pressure, which can result in gear drive failure due to lack of oil .
Another update changes the main gear in the drive from a gear with holes in the sides of it to a solid gear . Failure of this gear was evident by missing teeth or cracks running from the gear teeth to the holes.
The Dog hub has also been update from a two dog hub to a 4 dog hub. On the old system if the engine has a prop strike the gear drive would have to be taken apart to reposition the hub. With the new 4 hub system it simply jumps to another hub .
On C drive model gear drives the torque value has been updated on the gear retaining nut. Another common problem with the C drive is a leaking seal at the back of the drive. Signs of failure of this seal will be gear oil coming out of the two holes on the side of the drive, where the rubber coupler is visible.
Cost of Rotax reduction drive $ 800. (model A or B)
Cost of Rotax reduction drive $ 1100. (model C)
Cost of new Haegar Belt drive system $ 900.
Index
Approximate prices
Cost of replacement belts $ 8. (each-4 belts required)
Cost of replacement single belt system $ 35.00 - $ 50.
Cost of bottom pulley $ 60.
Cost of top pulley $ 160.
Cost of flex coupler per Ultralight systems $ 150.
Cost of standard coupler per Ultralight systems $ 49.95
Bearings $ 15. - $ 35. (each)
Rotax Gear box update kit $ 35.00
Gear hub update $ 42.50
Rotax drive gear $ 98.00
Engine: In the early days of ultralight aviation we would strap just about anything that would turn a propeller onto the front or back of our craft. A rule of thumb was not "if the engine quits" but "when the engine quits," be prepared for a forced landing!
When buying, try to buy a craft powered by an engine that parts or a replacement engine, are readily available. You will find that replacing an engine, with another make and model, will usually mean that you will also have to buy a new prop and redrive as well.
A good way of judging the condition of the engine is to remove the exhaust/ intake manifolds, and the cylinder heads. You can do this for the cost of replacement gaskets and about 30 minutes worth of work. This allows you to view the pistons, both front and back, as well as the top. Any kind of scoring means the engine has had a seizure requiring in most cases an engine overhaul. If carbon deposits are visible below the rings it means ring seizure, or piston/cylinder wear. This also means engine rebuilding. If the top of the piston shows signs of foreign material embedded in the head it usually means, the engine has ingested something or an internal engine component has failed! A damaged piston dome could indicate; a problem with ignition timing, spark plug heat range, lean fuel mixture, low octane fuels.
For better understanding read Troubleshooting the Cuyuna Engine Ultralight Flying Magazine. Trouble shooting the Rotax Engines Volume 1 - 2 - 3 L'il Hustler Enterprises, Ultralight Advisory Bulletins Ultralight Flying, or in video form, from L'il Hustler Aviation.
Other areas to look at are; the cowls surrounding the engine , the fan tower , intake manifold(s) recoil housing ignition wiring especially on Kawasaki, Cuyuna engines using CDI ignition, failure of the wiring occurs where wires engine CDI box. If engine is equipped with Rotax electric start look to see that spacer between magneto and flywheel has been update from that shown on left to that on right. Check the magneto for damage, caused by improper propeller balance, loose magneto nut, substandard motor engine installation. Also check to make sure wiring has not been pinched or burnt . A poor ground on electric start, will result in severe damage to electrical system.
Look at the physical appearance of the engine! It should be clean! Any sign of leakage from gaskets, or seals means the engine requires disassembly, replacement of parts and reassembly. A leaking seal or gasket can result in, erratic engine performance, overheating, lack of performance and or engine failure!
Gasket sets $ 100. - $150.
Labour rates for engine tear down $ 40. - $ 60. per hr.
Pistons $ 150.
Rings $ 30. (each)
Wrist pin bearings $ 25. (each)
Engine rebuilding videos and manual $ 69.
CDI box for Cuyuna/Kawasaki $ 200. (if you can find one)
Ignition coil $ 50.
277 Rotax engine
447 Rotax engine
503 Rotax engine
582 Rotax engine
340 Kawasaki engine
Zenoah engines
Hirth engines
Index
Propeller: The propeller is usually the most neglected part of the propulsion system. Yet it is what takes the power and creates the thrust which result in the wings developing lift. An improper propeller can cause the engine to over rev, resulting in overheating and engine failure. Under rev resulting in poor climb, usually resulting in an accident. It also is subject to a great deal of stress, from changes in engine RPM, aircraft attitude, and vibration from the engine, and improper prop balance. It is also subject to environmental damage from the sun, wind, rain, and ground. Propeller failures have resulted in engines being completely separated from the aircraft, resulting in loss of control, causing serious injury and death!
Check the prop for nicks or cracks
Check it for signs of environmental damage, rotting, paint pealing.
Check the inside of the hub area on older Warp Drive and IVO props for cracking .
Check bolts that hold it to the reduction drive for bending, rust, corrosion.
Check the prop spinner for cracks . On aircraft using the Ultraprop, in a tractor configuration it is recommended that the prop spinner not be used, or be securely wired on.
Check the prop for proper diameter and pitch, for reference use the prop guide chart found in the CPS, Leaf, catalogues. For more prop information it is suggested you read Ultralight Flying, on props.
If the craft you are buying is going to be on floats make sure the prop has some kind of leading edge protection. Without leading edge protection your prop will be a wall ornament after the first take-off! Props range in price from $150 - $1,000.
Control system: The control system is a part of the craft that has to be checked thoroughly! Some older designs used ROPE, to operate control systems . Do not fly any aircraft that uses rope and knots to operate a control system. Have these replaced with steel cable, using proper NICOS, and AN fittings. shows a manufacturer using a plastic clip to connect rope to control system. In Canada one of these, operating the elevator control system, failed during winter conditions, when under load it cracked and broke resulting in the owner of the aircraft being hospitalized for 6 months. The aircraft was completely destroyed!
Another problem in enclosed ultralights is dirt and debris collecting around the control cable where it enters, a plastic outer cable. The dirt acts much like sandpaper or a file, resulting in the cable fraying and failing . If the outer plastic coating moves in the retaining clamp, it allows metal on metal contact, resulting in failure of the control cable, or failure of the retaining clamp. This can result in loss of elevator or rudder control as happened at Sun N fun, causing a CGS Hawk to crash.
Other control system failure may result form the cable rubbing against tubing or metal .If your aircraft control system uses clips and rings to connect push pull tubes or cables to a elevator or rudder it is recommended that this be replaced with AN nuts and bolts .
Many ultralights use teleflex cables to operate control systems. When subjected to environmental conditions such as severe wind, these have failed, or partially failed. I test flew Buccaneer SX without noticing that the cable, operating the ailerons was cracked. It failed in a turn it resulted in a spiral turn, luckily it was not very steep and I was able to right it with rudder, and landed safely. When storing a craft outside it is suggested that you make up a set of aileron/elevator stops.
Check all moving parts of the control system for wear or damage. Look at the aileron hinges for cracks. In an aircraft using rivets look for loose fitting hinges, a sign of rivet wear. Examine elevator horns, aileron push pull tubes, rudder pedals, at attachment points for wear at hinges or eye bolts.
Elevator horn $ 50.
Teleflex cable $ 46 - $ 50.
Steel control cable per ft. $ .30 - $ .50
NICO press stops $ .20 - $ .85 (each)
Elevator/aileron stop material
2 lengths 10 ft. 3/4 inch copper tubing (available at any hardware store) $ 6. - $ 8.
10 feet pipe insulation $ 4. - $ 5.
2- 3 inch bolts and wing nuts $ 2.
Index
Landing gear:
Check the tires for wear
Check the wheel bearings for signs of failure.
Check the rim for signs of damage.
Check the landing gear welds or attachments area where the wheel and landing gear join together.
Check the landing gear for signs of bending
Check landing gear for signs for cracking or elongation of holes .
Tires $ 13. - $ 19.
Tubes $ 6. - $ 20.
Rims $ 20. - $ 60.
Wear bearings $ 2. - $ 15.
Landing gear:
MX axle $ 65.
Buccaneer XA $ 79.
Kolb
Rotec Rally
Challenger
Rans Coyote
Quicksilver GT
Maxair
Wing Assembly: Use a Maule tester/fabric tester to test fabric. My recommendation is not to fly on fabric that tests less than 41 lbs. on Maule tester . (Another tester available from Leaf/CPS/Airstar/Southern Mississippi uses a different kind of
scale).
Look at the fabric on top of the wing which has been exposed to UV, and the fabric on the underside of the wing. If there is any significant difference in color, then the fabric is ROTTEN. Before buying a craft run your hand along the fabric, if it comes away feeling greasy then the fabric has been coated with AP 303 or Armoural. These products make old rotted fabric look like new! Reports done by several groups have shown that UV deterioration can happen in as little as 6 months to aircraft left unprotected in the sun.
Check baton tips for breaks or cracks. On many older designs it was necessary to safety wire the batons, directly in front of the prop, as they tended to move out during flight! OUT INTO THE PROPELLER!
If Velcro is used on the aircraft check to make sure that it is still "STICKY". Many pilots have reported the Velcro attachment points coming "unstuck", in some cases this has resulted in fuselage covering material entering the propeller .
Check the leading and trailer edge for signs of damage. Check the strut attachment points. Check the wing attachment points. Many early manufacturers used the type of bracket shown on the left in fig 71. These have failed in flight. Most are not using that shown on the right in fig 71, it is suggested to you consult the aircraft manufacturer or someone knowledgeable in the industry for advise if the craft your craft uses these stainless steel brackets.
Fabric replacement cost:
MX $ 712.
MX11 $ 757.35
MXL $ 1306.
MXL11 Sport $ 1418.
Chinook $ 2,000.
Maxair $ 950.
Rally
Beaver RX 550
Beaver RX 35
Buccaneer XA
Buccaneer SX
Buccaneer 11
Baton tips $ 1.15
Maule Tester $ 179.95
Quicksilver Tester $ 47.99 (leaf part # 60100)
UV protection $ 84.90 Stits AO-100 / gallon (average 2-3 gallons per aircraft)
Index
Parachutes: If your parachute is more than 5 years old it more than likely needs to be updated to a new system. There have been several manufacturers producing units for ultralight aviation. Today there is only one North American company BRS. BRS systems have undergone extensive changes over the years that they have been in business. It is suggested that you contact them directly at:
BRS - click here to go to our BRS section!
Two areas of major concern are in the deployment handles, or firing mechanism. These corrode! This corrosion results in system failure!
Another area of concern is in the mounting location. To date I know of several incidents where the parachute has been fired, but the system deployed into part of the wreckage of the aircraft, causing late or only partial deployment.
BRS repack and update
As you can see there are a great deal of things to take into consideration when buying a used ultralight. You can also see that the aircraft you are considering buying for $10,000 could be worth considerably less!
:roll: :roll: :roll:
Bennie Vorster
083 277 5110
KFA
Postby KFA » Fri May 04, 2007 9:06 pm
Bennie, jy sal dat jou vrou moet deepheat aan jou tik vingers smeer. :shock: Briljante sisteem. Moet hom as 'n sticky by die for sale afdeling sit :wink:
Aerosan
Postby Aerosan » Sat May 05, 2007 8:15 am
Deep heat :?: :?: :?: ek dink meer na n fisioterapeet :!: Thanx Bennie sekerlik baie interresant en n klom info daar :P
Job well done sir :wink:
The Agent
Postby The Agent » Sat May 05, 2007 6:22 pm
Benna mooi dese maar daar was meer as tien punte ou maat. :wink:
Empty Toy Box
Busy Arranging for new toy.
Graham Cooper
Postby Boet » Sat May 05, 2007 10:18 pm
Mmmmmm jaaaaaa, deur skand en skade raak men wys....... :wink:
