Lessons learnt from an EFATO
Postby Bundy » Fri Dec 13, 2013 6:18 am
Really good Article taken from Avcom.... :)
Low Level Engine Failure After Takeoff
Some Lessons Learnt from an EFATO in a Jabiru
By Manny Peralta CPL, AUF 010869
Having survived an EFATO, I have been asked by a fellow pilot, to write about the experience. I propose to discuss human factors and aircraft performance issues, which hopefully, will give a realistic feel for an EFATO.
The most important lesson that I have learnt from this experience, is that a simple and purposeful plan of action is absolutely necessary for survival. Complicated plans that need perfect coordination and leave little room for error, such as turning back after takeoff, are more than likely fatal. I knew two pilots who died because they turned back after an EFATO. Both were highly experienced commercial pilots with thousands of hours in their respective logbooks. Let’s now look at the human factor issues.
The EFATO I experienced, happened at approximately 300 feet AGL with the engine at full power, and the IAS set a Vy (65 KIAS). Incidentally, the published glide speed for this aircraft is also 65 KIAS. The engine finally flamed out after hunting badly from full power to zero power; three times in quick succession. The sound of the engine hunting, reminded me of a flying instructor quickly pulling and pushing back the mixture control of a Cessna 150, whilst trying to simulate an engine failure.
Despite years of flying experience, my mind froze for what appeared to be an eternity, when the engine stopped. I kept on thinking: this can’t be happening to me. I suddenly felt sad, thinking that I might not survive to see my baby son grow up.
I have read that a typical light trainer takes 35-45 seconds to descend to the ground after a low-altitude EFATO at gliding speed; time is indeed precious. In hindsight, I have learnt that the inability of the brain to accept the emergency is what kills. A brain in denial, means that the pilot just sits there doing nothing; uncontrolled panic becoming a great possibility.
With a low-altitude EFATO, there is no time for anything else but to lower the nose to a safe glide speed and to pick a field. There is no time for looking inside the cockpit, nor time for using elaborate rote checklists. By intuition and feel, I set the best attitude for the glide, picked a field and closed the throttle to prevent a fire. After those three actions, the aircraft basically touched down.
Panic and time compression are critical issues that must be managed in an EFATO. I survived, because I psychologically prepared myself by doing a quick mental self-brief of what I would do in an emergency; great emphasis being placed on simplicity. I don’t use mindless written checklists, but I do use a system where I commit critical emergency actions to memory.
For me, the most frightening thought just after an EFATO, is the overpowering urge to turn back despite the high risk of a stall and spin. It seems that fear and self-preservation, can overcome logical thinking and training. I only just managed to fight off the urge to turn back, by shouting to myself repeatedly over the intercom: “don’t turn back! For a split second, I also remembered a friend, who died when he apparently tried to turn back after an EFATO, from the same runway that I took off from that day. Being a young family man, a fiery death for me was definitely not an option!
In summary, regardless of flying experience, the human mind’s natural response to an EFATO is fear and self-preservation. This same fear can create denial; panic may then occur, creating poor decision-making and inactivity. The urge to turn back was by far, the most destructively powerful thought that I ever experienced during the EFATO. Using a simple mental plan like: lower the nose and pick a field, before takeoff, helps the pilot to overcome this type of dangerous and illogical thinking. Denial, fear and panic are the killers: not the engine failure itself.
Let’s move on to what the aircraft felt like, when the engine stopped. I must qualify this part of the article, by stating that I was flying a low-inertia aircraft (430 kg MTOW), which may perform differently during an EFATO, compared to heavier and faster Cessna, Piper or Beech aircraft.
As stated earlier, the engine started to hunt from full power down to zero power three times. It felt like a flying instructor trying to simulate an engine failure, by pulling and pushing the mixture control. Everytime the engine was at zero power, the control column and rudder pedals felt spongy and limp; which I suspect came from the reduced slipstream and dynamic pressure over the control surfaces.
The engine finally stopped, with the control column and rudder pedals feeling permanently limp and spongy even at the Vy of 65 KIAS. The Jabiru felt like a Cessna or Piper trainer on the verge of an aerodynamic stall. I remember thinking: why do pilots turn back, if the controls feel this way?
When I lowered the nose by feel, to the best glide speed, the aircraft still felt like it was descending at a high rate; the drag of the fixed undercarriage and windmilling fixed-pitch prop may have been the cause. In hindsight, simulated engine failures, with the engine at idle power are, in my experience, inaccurate representations of the real thing. Instructors and student pilots beware!
I was able to flare the aircraft to further reduce the apparent high rate of descent; the aircraft responded normally. The field I picked was a flat disused paddock with very short dry scrub. The touchdown felt normal, but the ground run felt like a very fast car driving on a heavily potholed road. My feet were being violently kicked off by the rudder pedals, as the nose wheel ran through some rough terrain; amazingly the nose gear remained attached to the aircraft.
Although strapped in tightly, my body was thrown violently from side to side, as well as up and down. The instrument panel was a blur, as the undercarriage crashed through small mounds of earth. Luckily my head did not contact the aircraft structure. Trouble lay ahead however, as a rapidly approaching barbed wire fence, filled my view.
My old Tiger Moth instructor once taught me how to groundloop, as a last resort in avoiding obstacles. It must have worked, because I walked away from the crash uninjured.
Just before hitting the fence, I pushed in some right rudder, which started to give me a right groundloop. The left metal wing strut crashed through the wooden fence posts, sounding remarkably like a sledgehammer smashing through a guitar; the barbed wire making a deep humming sound as it stretched, with the left wing sliding along the wires! Eventually, the left wing sheared off at the attachment point to the fuselage, and the nose gear collapsed, as it dug into a mound of soft earth. At that moment, the Perspex transparencies exploded into large jagged shards, sounding like breaking bottles. The fuselage was still making moaning and crunching noises, apparently twisting itself, as it came to a sudden stop balanced precariously on its nose.
The Jabiru’s sudden stop smashed my upper body hard against the already tight seatbelts, causing air to explode from my lungs with a sickly grunt. I was afraid that the aircraft would somersault upside down, as it teetered on its nose for a split second. It suddenly fell back onto the still-attached main undercarriage. I immediately thought fire!
With hands and legs quivering nervously, I flicked off the electrical and fuel switches and crawled through the smashed windshield. The barbed wire fence blocked my exit from the pilot’s door. I found my small Nav Bag outside the aircraft, about a metre from the nose. Big lesson: ensure that potential missiles are secured properly in the aircraft. I suspect that the Nav Bag helped cause the windshield to smash completely, as it flew off the co-pilot’s seat.
I agreed to an ambulance ride to the local base hospital, for a check up. The only injury I sustained was a smashing headache, from the bloody neck brace, that an idiotic young GP; who fancied himself a bit of a god-doctor, insisted I wear! Afterwards, it was a packet of Panadol and a car ride home for me!
In conclusion, I have learnt the following lessons:
The pilot’s initial shock and denial after an EFATO, can easily overcome logical thinking; extensive flying experience may not necessarily protect a pilot from this danger;
Prior planning is a very effective way to help expect the unexpected;
Turning back after an EFATO will almost certainly be fatal: two fellow pilots I know are dead because of it;
Forget the rote checklists, the only priority is to fly and pick the best field;
Practiced engine failures at idle power, are generally poor representations of a real EFATO;
With the reliability of modern aircraft aside, if you fly long enough, you will eventually experience some sort of emergency: no pilot is immune!
Chapman
Re: Lessons learnt from an EFATO
Postby Chapman » Fri Dec 13, 2013 10:36 am
Hi Bundy,
Wow!, what a great article and an unselfish learning experience that he shared with everyone, who knows, this might save someones life in the future. Thank you.
I am a wannabe pilot and am still in the dreaming phase for the last ...... 10 plus years. What I do know is that "one day is one day" and this is luckily not depending on the lotto. I love this Forum and everybody that contributes here, the humor is great, there's a great vibe within this flying community and I drink everything in that is said here. One day this will make it easier for me when I do my licence. If I get the chance when I go to the big city then I go for a flip in a trike and I love every moment of it. I think I learn a lot here, especially if I read about this experiences like this one. I frequently view all the trikes for sale and in my mind I start putting my trike together.
I thought this could also contribute to the experience that I read here. This is just a piece that I took from a fantastic book book by Anthony Robins on how the mind reacts in situations like this. This is a 99 page book which Anthony Robins offers for free, so if anybody is interested to have it, I will be more than willing to give it to you, just let me know. Thank you for everyone one who helps me to color my dream!!
"A fantastic metaphor for the power of focus is racing cars—a real passion for me. Driving a Formula racecar can sometimes make flying a jet helicopter seem like a very relaxing experience! In a racecar you cannot allow your focus to wander even for a moment from your outcome. Your attention can’t be limited to where you are; neither can it be stuck in the past or fixed too far in the future. While remaining fully aware of where you are, you have to be anticipating what’s about to happen in the near future.
This was one of the first lessons I learned when I started racing school. The instructors put me in what’s called a “skid car”—an automobile that has a computer built into it with hydraulic lifts that can pull any wheel off the ground on a moment’s signal from the instructor. The number-one fundamental they teach in driving is: Focus on where you want to go, not on what you fear.
If you start to skid out of control, the tendency, of course, is to look at the wall. But if you keep focusing on it, that’s exactly where you’ll end up. Drivers know that you go where you look; you travel in the direction of your focus. If you resist your fear, have faith, and focus on where you want to go, your actions will take you in that direction, and if it’s possible to turn out of it, you will—but you stand no chance if you focus on what you fear. Invariably people say, “What if you’re going to crash anyway?” The answer is that you increase your chances of survival by focusing on what you want. Focusing on the solution is always to your benefit. If you have too much momentum in the direction of the wall, then focusing on the problem just before the crash is not going to help you anyway.
When the instructors first explained this to me, I nodded my head and thought, “Of course! I know all about this. After all, I teach this stuff.” My first time out on the road I was screaming along, and all of a sudden, unbeknownst to me, they pushed the button. I started to skid out of control. Where do you think my eyes went? You bet! Right at the wall! In the final seconds, I was terrified because I knew I was going to hit it. The instructor grabbed my head and yanked it to the left, forcing me to look in the direction I needed to go. We kept skidding, and I knew we were going to crash, but I was forced to look only in the direction I wanted to go. Sure enough, as I looked in that direction, I couldn’t help but turn the wheel
accordingly. It caught at the last moment, and we pulled out. You can imagine my relief.
One thing that’s useful to know about all of this: when you change your focus, often you don’t immediately change direction. Isn’t that true in life as well? Often there’s a lag time between when you redirect your focus and when your body and your life’s experience catch up. That’s all the more reason to start focusing on what you want quicker and not wait any longer with the problem.
Did I learn my lesson? No. I’d had an experience, but I had not created a strong enough neuro-association. I had to condition in the new pattern. So sure enough, the next time I headed for the wall, the instructor had to loudly remind me to look at my goal. On the third time, though, I turned my head deliberately and consciously. I trusted it, and it worked. After doing it enough times, now when I go into a skid, wham! my head goes where I want it to go, the wheel turns, and my car follows. Does this guarantee I’ll always succeed by controlling my focus? No. Does it increase my chances? One hundredfold! The same thing is true in life. In later chapters, you’ll learn some ways to make sure you condition your focus to be positive. For now, realize that you’ve got to discipline your mind. A mind out of control will play tricks on you. Directed, it’s your greatest friend."
Flooi
Survived first engine out
Postby Flooi » Fri Dec 13, 2013 1:40 pm
Great article! (^^)
Postby Bundy » Fri Dec 13, 2013 1:44 pm
Chapman wrote:Hi Bundy,
. I love this Forum and everybody that contributes here, the humor is great, there's a great vibe within this flying community and I drink everything in that is said here...
You gonna fit right in!
After flying.... we also drink..... everything! :lol: (^^)
Turbo
Postby Turbo » Wed Dec 18, 2013 1:30 pm
Makes me kak myself!!! Now i want to go and open my cowls and check every little thing for correct operation and every clamp for tightness etc etc.....
Well thank goodness for the long ass runway at FASI -- and plenty open ground surrounding the airfield.....
KFA
Postby KFA » Wed Dec 18, 2013 9:36 pm
There are only 2 types of pilot's. The ones who had an engine out and the ones who are going to have one. Practice those EFATO's and emergencies. Take a flight with an experienced and respected instructor and actually switch off the engine and feel what the plane feels like. It might save your life one day.
Turbo
Postby Turbo » Mon Dec 23, 2013 9:04 pm
hey guys
something very interesting and confirms the writters comments -- I did a few simulated engine outs with the engine running at FASI on Saturday, then did a few with the engine off - heres the results
1) engine running, I noticed idle speed was not at idle, it was around 2800RPM -- the planes glide ratio was very good.
2) engine off -- TOTALLY different aircraft!! The prop did not stop rotating immediately, it slowed and eventually (because of the high compression 912 EXTRA) stopped with a jerk. the plane felt like it suddenly flew into a 50MPH headwind and the glide ratio was around half of the simulated engine out with the engine running. I did this again and again with the same results -- and man I tell you its easy to restart in the air, but if you cannot, DO NOT THINK THAT YOU WILL JUST SOMER MAKE THE RUNWAY .... NOT UNLESS YOU ARE ABOVE IT OR YOU ARE VERY HIGH AND HAVE TIME AND CHOICE.
we did the same test in a cheetah with a 912 100HP and same wing etc - this engine does not have the same compression as my 912 Extra 95HP and the prop did not stop rotating.... BUT it also slowed down a lot more compared to the 'idling engine'
test this for yourself so you learn your planes characteristics.... and for goodness sake do it ABOVE your runway not hundreds of feet away!
Users browsing this forum: No registered users and 28 guests
