Windlass with a lectric motor
witwillem
Postby witwillem » Thu Feb 07, 2013 10:38 pm
Jis people's my Windus is starting to get tired, Ja it is nearly at 800 hours so we deside to fit a lectric motor . We got a wold grasscutter wif a lectric motor so we put the rattan mother wif all the gedoentes in the waenhuis and we fit the lectriek wif brakets on the the trike . We put the fonjong generator 5 kw on the back seat and start it up , but now the propeller turn to slow , so my uncle cut 3 inches of the points , now is better but still to slow . I get the iron saw and we takes 4inches more of now it rev like a cortina gt , but we can't get off the ground , we want to be at the tedderfield on Saturday wif the first lectriek trike so people's Julle Moët help we is going to put the water pomp engine on tomorrow ' will it fly , we get a info prop from Karel Menge at marble hall . If this work not we will put it on trailer and drive there, we sommer want to sort out daai groot ek ou from the pilot Korant ok , how do we get there . Se maar hoe kom ons daar Willempie
Re: Windlass with a lectric motor
Postby nicow » Fri Feb 08, 2013 7:23 am
Sien julle daar.As ek jou die pad moet verduidelik sal julle by Sun City slaap (**)
Hadams
Postby Hadams » Fri Feb 08, 2013 8:41 am
Hi Witwillem,
Die maklikste sal maar wees om hulle te "google"! Anders praat met die manne van Microland, glo gaan hulle na Panorama toe vlieg en van daar na Tedderfield! Dis seker so 5 myl van Panorama af!
Sien julle daar!
Henry.
Henry Adams
ZU-CEA Raptor Trike
ZU-FTV Sling
Panorama
witwillem
Postby witwillem » Sun Feb 10, 2013 9:06 pm
Yes peoples, what weekend, the generator nearly killed me , we use the wolf grasscutter machine hand starte for speed control an it it a too speed , to fast and two slow , maar that's that en jou ous knows us Vd Walts we makes aplan . We put the generator on the back seet without the frame , we weld angle iron brake tang take the engine out the frame and put it where the back seat was , the petrol tank is now the windlas tank wit h a 12 volt lectric ford Sierra fuel pump.we make the propellor bit shorter , so 2 and 3quater inch , now we gets refs an baie thrust , we takes a try flight and just as we Ge into the sky over over loss blik kiss se hoe near farm the safety belt holding the engine fas starts melting on the exhaust and the engine generator falls off and the chickens must run for their life , the trike is now a glides , wif out engine and the only place to land is after the vark plaas van Jp Vd Walt far of cousin . Ja one helle smash I take off the roof and the varkens run rub all over the Jaart.Tneef far of was very cross and he say he report us to he polices if we don't fix the barkers hok before the sun go down today , Ja you ous no us we makes a plan , the varkens now have a See fru sun roof , Nogal fiber glass , so that is why we did not get to tedderfield by the way the generator is nou in sy nut in , I looks for 7 kva generator now. Groote Willempie (**) (**)
witwillem
Postby witwillem » Mon Feb 25, 2013 6:59 pm
Ek is op soek na n Toyota electriek Karen Wat verongeluk het , die battery en die lectriek motor kan dalk week innie windlass , het n video gesien van so iets in Tasmania , wil graaf so een pas my humdinger motor is te swak (**) help asb Willempie
Dobbs
Postby Dobbs » Thu Feb 28, 2013 7:10 pm
WitWillem, I think wat you must do is think out side of the doos, and I wus thinking that you can leave the generator what is in sy nut in and jus get for you a long xtension wat can let you fly wifout any 5 kilobite generator.
But I think that if you do circuts, you must do one left hand downhill, and then next one must be right hand down hill other wise you get a big not and then the krag doesnt come through to the lectric motor.
All the best - I jus wanna see some fotos of your machine (^^)
Postby Gyronaut » Thu Feb 28, 2013 7:40 pm
JA, ons soek kiekies! :lol:
witwillem
Postby witwillem » Wed Mar 13, 2013 8:07 pm
Thank you ous for the good advice , but you souties should know by now ons boere makes a plan. Ja ek het gelding oor die left hand downwind circuit , maar die drade is te naby aan die bome so nou Gaan ons die sender pivot se pipe af halal en die blou adventura plug daar I plug. Yes we got a plan we can fly in the round like a merry go round and we can even take the floppies for a flip , we is now cutting the mielis off because it is very dry and Saturday we will fly in the round - the kotsklitser Wat wants kiekies can come and check for himself , Ja we will even take the kinnerjies van Abraham Kriel kinnerjies huis for the ride of their life , sal weer met Julle Praat later Willempie
Postby Gyronaut » Wed Mar 13, 2013 8:50 pm
Bwahaha @ kotsklitser!
:lol: :lol: :lol:
Dobbs
Postby Dobbs » Thu Mar 14, 2013 11:17 am
yes no, you boere know how to maak a plan. You mus just practice very well your emergency landings as you will never know when eksdom will jus can like to switch off the krag and you will know that when the fan stops blowing, it gets very hot
