I struggle to get tyre off rim
witwillem
Postby witwillem » Thu May 12, 2011 8:15 pm
I buy new tyre for my Windlass .
Die blerrie tyre is vasgegroei aanie rim, Ons het al alles geprobeer om hulle los tekry .
Ek het een tyre met die knipmes gesny maar hy sit nog steeds vas - Gee raad asseblief ek wil die naweek vlie Willempie ## ## ## ## ## ##
Re: I struggle to get tyre off rim
Postby Boet » Thu May 12, 2011 8:36 pm
Plat skroewedraaier probeer? Of gebruik die bankskroef om die taaier los te druk van die rim af. Hulle sit nogal baie vas partykeer. Mes is nie n opsie nie! :lol:
lambada
Postby lambada » Thu May 12, 2011 8:48 pm
So maak mens....................
Sit rim in son met n sterk mengsel van water en sunlight liquid of flight hand cleaner tussen rim en tyre na sowat 60 minute behoort die rim los te kom
Probeer maar en laat weet asseblief.................
Pieter Roux
KFA
Postby KFA » Thu May 12, 2011 9:03 pm
parafien werk ook in die son. Kruip oral in
Postby Madman » Fri May 13, 2011 8:01 am
Or just take it to a bike shop...
Yamaha did mine in 10 minutes ##
s023
Postby nicow » Fri May 13, 2011 11:09 am
I broke the rim....
Alkemac
Postby Alkemac » Fri May 13, 2011 11:24 am
Swop it with someone else's dm:
ZU-DODO
witwillem
Postby witwillem » Sun May 15, 2011 5:37 pm
Jis I still sukkels - I say thakyous to all the peoples who send raad - I try parrafien , Fight hand cleaner , bankskroef , widoleen diesel alles - die blerrie thing sits vas , surf ome lifebooy itd work not .
I loads 15 arbeiders on the bak of the cortina big six and we try to trap it off , still it sit vas like meide k op n poliesie kobers . Now I is raadop . I try the tire shop and the break the blerrie rim .My ma ay we must make it warm in the seep pt so we make fire and we cooks this rims but stiil is vas - is like n teef op hitte met die bure se boel . I get ou Jafta the baas boy i hive him a half jack blits and a 3pond hammer and tire lever and say he must put the tire in the bleek son and put som merresyne op en slaat hom af . Jis half hour late he come back wif two off tires and the derde stukkende rim ook af .
Jis jong it show nofing is kproef so if you sukkels ou jafta wif half jak he kan Willempie ## ##
avgas
Postby avgas » Sun May 15, 2011 8:13 pm
Dinamite
Balls to the wall
Postby Madman » Mon May 16, 2011 10:30 am
:lol:
Users browsing this forum: No registered users and 29 guests
