some more info to that: The winds and temps are actuals from the weather balloons. These balloons are sent up twice a day, at 0000Z and 1200Z. The red line indicates the lapse rate, which is an indication of stability etc. The winds are obviously also actual winds as measured whilst the balloon ascended.select Low Level wind profiles and choose a station near you
