We had breakfast at an airfield on Saturday morning.
Two trikes landed and were parked next to the restaurant with people having breakfast.
When these two guys decided to move on they started the engines with the props facing us having breakfast. After warmup full throttle blowing our food full of grass and dust.
It would have taken them less than a minute to move the trikes 90 degrees away from the people having breakfast.
Airmanship is not only applicable in the air but also on the ground.
Poor display of Airmanship
Re: Poor display of Airmanship
If it will help our cause, publish the registration numbers...
ZU-DODO
Let's not do the name and shame option. If you have the registration numbers then we can find out who they are, and give them a talking to
- John Young
- The Boss
Hi,Morph wrote:Let's not do the name and shame option. If you have the registration numbers then we can find out who they are, and give them a talking to
Agreed - there are enough Cyber Kangaroo Courts out there already.
John ZU-sEXY
In past we have just jumped on the radio there and then and usually they are apologetic. I have seen it a couple times and from experienced aviators. Problem is often the added pressure of a "crowd" and they are so hell bent on not making oops in public and then forget "outside" effects....
Don’t want to name and shame them.
Just take care when you are starting up that your tail is not facing the public.
T-Bird, You are so right. I don't believe guys try and blow the public away. Sometimes they just don't think. It's happened to me too.t-bird wrote:Don’t want to name and shame them.
- JJJ
- Solo cross country
A guy in a two seater Jabbi once started his Jabbi with my plane right behind him. All I did was walked up to his plane, pushed the tail down and turn it 90 degrees. He and his wife got such a groot skrik and nearly jumped out of their Jabbi.
Not the right thing to do I suppose but I can promise you he will never do it again.
JJJ
JJJ
- Blue Max
Yes it is not very often that somebody is having breakfast behind your aircraft.
I can only immagine that they were not doing it on purpose.
Thanks for the entry, to me it is a fresh reminder to be wide awake..
Should be plain common sense, basic manners and awareness. This is why we normally stop to have breakfast
Fly by wire
in what way does this differ from an incident ?
clearly we have people exposed to more than an acceptable level danger and risk ?
ZU-DODO
No additional risk!!
You expose yourself by having breakfast next to a runway!
- Tumbleweed
Simple mistake and only happens once. Like blasting from a standing take-off on a dust strip with all your mates lined up behind you.
Users browsing this forum: Bing [Bot] and 10 guests
