Removing Buff Tape
skidmark
Removing Buff Tape
Postby skidmark » Tue Aug 11, 2009 8:14 pm
Just stripped the old sails off my Challenger to find that the leading edge and trailing edge have brown buff tape on. It looks bad and I would like to clean it off and replace with some new stuff. I have tried thinners, acetone and paint remover. The only one that sort of helps is thinners but, it takes 1 litre to move 500mm. I rap a cloth around the tubing and soak with thinners and wait a LONG time. ANY SUGGESTIONS??? All welcome please!!! (Not sure if this post should be under technical? If so please Mr moderator move it.)
KFA
Re: Removing Buff Tape
Postby KFA » Tue Aug 11, 2009 8:21 pm
Try Silicone remover or Automotive pre-cleaner available from most automotive paint shops. Works like nothing else
Low Level
Postby Low Level » Wed Aug 12, 2009 9:27 am
The same stuff you fly with - 93 mogas.
I wrapped my bicycle going down to the Argus. Same sh!t. :?
Petrol is enige gom se baas. :wink:
ZU-CFW
skidmark
Postby skidmark » Wed Aug 12, 2009 10:07 am
KFA wrote:Try Silicone remover or Automotive pre-cleaner available from most automotive paint shops. Works like nothing else
Sorry this doesn't work either. It will remove the glue stuff but does not break down the plastic tape itself. Can't find anything that can get through this. :(
Need something to penertrate the plastic film first the rest is easier.
Grumpy
Postby Grumpy » Wed Aug 12, 2009 11:36 am
Hey Skiddo, You need some grease.............................. Elbow Grease (^^)
mak
Postby mak » Wed Aug 12, 2009 11:53 am
Low Level wrote:The same stuff you fly with - 93 mogas.
Didn't know we had 93 mogas in the country that long ago :wink: :wink:
www.altairaviation.co.za
vernon11
Postby vernon11 » Wed Aug 12, 2009 6:12 pm
Dont laugh!! But try parrafin. Let it soak for quite a while, then try.
skidmark
Postby skidmark » Thu Aug 13, 2009 8:17 pm
I'm kind of gatvol now. Got a Bosch heat gun going give that a go tomorrow. Object is to get the actual tape off. To clean the glue stuff is not a hassle. There are tons of products to do that, most I have mentioned before. Fortunately I'm removing from bare aluminum not a painted surface. I was given a special wheel to try that panel shops use, a German product looks like a biscuit and smells quite lekker too. Attach to a drill and it works like a dream at R250.00 a wheel. Comes from the suppliers packed in a box of two. I think little to expensive to remove buff tape! So lets see what tomorrow brings!!!
Postby Duck Rogers » Thu Aug 13, 2009 11:59 pm
Benzine and elbow grease.... vhpy
skidmark
Postby skidmark » Sat Aug 15, 2009 8:45 pm
Ok, I'm done 1 nil...buff tape wins! Calling it a day and leaving the old stuff there. Morph the genius, the maestro rolled up his sleeves and showed me how to do the stits on the wing tips. First wing recovered hopefully next weekend we can finish the second one and the following weekend I will have to be test pilot. But so far what a difference to that old crappy wing covering. It looks absolutely awesome. Thanks to Morph and my mate Joe. aka "Pinkfloyd" (^^)
