Full bladder on X country
Trikenut
Re: Full bladder on X country
Postby Trikenut » Fri Aug 01, 2008 7:15 pm
I LOVE this site. Hahahaha :lol:
My solution is still the best, KIDDING :twisted: vhpy
"Beware 16 year old here"
Flooi
Survived first engine out
Postby Flooi » Sat Aug 02, 2008 4:48 pm
Seriously: Frequent micturition can be linked to Diabetes or prostatitis and a visit to your md will
clarify. Also consider that liquids on an empty stomach will very soon reach your bladder. So either
haved breakfast before flights or refrain from early morning coffees.
andreb
Postby andreb » Sat Aug 02, 2008 5:31 pm
Flooi wrote:Seriously: Frequent micturition can be linked to Diabetes or prostatitis and a visit to your md will
clarify.
That's what I said!!
Ugly Duckling
Postby Ugly Duckling » Sat Aug 02, 2008 9:09 pm
Be careful flying with a full bladder.
Should you have a prang with a full bladder you could end up with a ruptured bladder which leads to all sort of medical complications, peritonitis http://www.healthscout.com/ency/68/473/main.html , which you don't need at all.
Paul Sabatier
The object is to fly, it does not matter what the object is!
Dre'man55
Postby Dre'man55 » Sat Aug 02, 2008 9:12 pm
Ugly Duckling wrote:Be careful flying with a full bladder.
Chances are it may be released along with everything in your bowel just before :wink:
Must get airborne again
Andre'
Flying Below power lines on a DSX650
Too much power is just enough
Postby Duck Rogers » Sun Aug 03, 2008 7:55 am
Morph wrote:What you are also taking about here is nerves. In the beginning, when you start to fly the nerves cause you to want to pee often. I always used to have to have a last piddle just before taking off. even if it ended up as a trickle, I needed it.
Also known as QNL................Quick Nervous Leak
Postby Morph » Sun Aug 03, 2008 10:32 am
hehe, Part of the preflight, between the inspection of the aircraft and getting in and starting up
Cali
Postby Cali » Sun Aug 03, 2008 3:44 pm
OK what you need is a cable tie and a hand full of pain killers. Slide the cable tie over the problem area and pull tight. Put the pain killers in your pocket, you will figure out what to do with them later. (**)
Airborne Edge X
32-4331
"BLUEY"
grostek
Postby grostek » Sun Aug 03, 2008 4:08 pm
Please describe how and with what this cable tie gets removed vhpy vhpy vhpy vhpy vhpy
He He He He He
Kind regards,
Gunter Rostek.
Postby Duck Rogers » Sun Aug 03, 2008 6:32 pm
grostek wrote:Please describe how and with what this cable tie gets removed vhpy vhpy vhpy vhpy vhpy
He He He He He
Kind regards,
Gunter Rostek.
That's easy Gunter............stick it in the fridge (**)
swiftprop
Postby swiftprop » Sun Aug 03, 2008 7:52 pm
Should'nt be a problem if you are flying a cropsprayer. Just have IT plumbed into the main supply tank provided the capacity of the tank is large enough. Maybe convert all long distance trikes to mini crop sprayers? :shock: :shock: Just joking...
grostek
Postby grostek » Sun Aug 03, 2008 8:06 pm
[/quote]
That's easy Gunter............stick it in the fridge (**)[/quote]
Gunter Rostek
Dre'man55
Postby Dre'man55 » Mon Aug 04, 2008 7:31 am
On a serious note and I don't know if it has been covered already, some of the offroad racing guys use adult nappies.
Andre'
