Page 2 of 12
Re: Ramp Inspection List
Posted: Wed Sep 17, 2008 10:54 am
by Morph
Morph wrote:Any idea of where we can get singal strips from?
I found these. You can get them at any aviation shop, they cost R150. they are foil strips to be used in case of emergency for ground to air signalling. I unerstand you lay them out on the ground to signal help needed, sos etc.
Posted: Wed Sep 17, 2008 12:49 pm
by Wargames
Morph wrote:Any idea of where we can get signal strips from?
Go and raid your wife's linen cupboard
Posted: Thu Oct 02, 2008 3:35 pm
by Cacofonix
Hi Morph, I was at Republic Aircraft Parts today. They at Wonderboom Airport in Pretoria. I bought signal stips there. R 355.00. It's white pvc, a thick type. It has 4 500mm x 2.5m stips a steel reflector and a signal internationally accepted code like paper chart. I,m sur one could make it up. However you can email one of the blokes there.
pelcher@lantic.net or call 012 567 5141/2/3 and they can send it to you. This blokes name is William
Posted: Fri Oct 03, 2008 9:25 am
by Morph
Is this what the card looks like.
Even if no ELT or distress signal has been received, a visual search will commence as indicated in your Flight Plan, or Flight Itinerary. The search will start along your filed track, between your last known position and your destination, and expand from there. Searchers will be looking for anything out of the ordinary and their eyes will be drawn to any unnatural feature on the ground. Your aircraft has the best chance of being spotted if large portions of its wings and tail are painted in vivid colours. Keep your aircraft cleared of snow.
Many searches take at least 24 hours before rescue is accomplished. As soon as possible after landing, build a campfire. Make your site as conspicuous as possible. A smoke/smudge fire of green material should be prepared for instant lighting should you see or hear an aircraft. Three
fires in a triangle is the standard distress signal. One of the best conspicuity items now available on the market is a cloth panel of brilliant fluorescent colour. It is staked to the ground during the day and used as a highly effective ground signal. It can also be used as a lean-to shelter and it supplies warmth as a blanket.
The following symbols are to be used to communicate with aircraft when an emergency exists. Symbols 1 to 5 are internationally accepted; 6 to 9 are for use in Canada only.
Nº.
MESSAGE CORE SYMBOL
1. REQUIRE ASSISTANCE
V
2. REQUIRE MEDICAL ASSISTANCE
X
3. NO or NEGATIVE
N
4. YES or AFFIRMATIVE
Y
5. PROCEEDING IN THE DIRECTION
(Make a large arrow, with the head pointing in the direction you are going)
NOTE: Use strips of White fabric or PVC sheeting, 500mm wide X 2500mm long. You will need 4. (I reckon one of moms sheets would work
Endeavour to provide as big a colour contrast as possible between the material used for the symbols and the background against which the symbols are exposed.
Symbols should be at least 2.5m in height or larger, if possible. Care should be taken to lay out symbols exactly as depicted to avoid confusion with other symbols.
A space of 10 feet should separate the elements of symbol 6.
Posted: Fri Oct 03, 2008 7:28 pm
by Cacofonix
spot on Morph chech your mail and fax
Posted: Sun Oct 05, 2008 5:04 pm
by Koevoet
Morph wrote:Morph wrote:Any idea of where we can get singal strips from?
Wa jy dit gekoop, soek ook asb?
Jaco
Posted: Mon Oct 06, 2008 8:55 am
by Morph
I was quoted R150 from the flight shop at Cape Town Aviation Business Centre at the airport.
021 934 4083
Posted: Mon Oct 06, 2008 9:31 am
by Morph
I am going to make up this card and have it laminated
Are there any numbers that we can put on the back that are crucial, i.e. Search and Rescue, CAA, police, emergency services etc. what do you think?
Posted: Mon Oct 06, 2008 11:23 am
by Tailspin
Posted: Mon Oct 06, 2008 11:45 am
by Morph
Here is a sample of the card A5, double sided. And Laminated
I am planning on using a white sheet, cut into 4 X 690mm X 2450 mm long. It can be used to signal, and at night offer some warmth
you can add a small polished alluminium plate to this as well 130mm x 80mm, and put the whole lot into a plastic document holder, A4.
Posted: Tue Oct 07, 2008 7:01 pm
by Arnulf
4 strips, 690mm x 2450mm make up quite a large packet.
Now where would I put this in my trike
Posted: Wed Oct 08, 2008 12:55 pm
by Cacofonix
Arnulf you could put the four stips on top of each other then fold the breadth in half, then roll the length up in 250mm and you'll end up with the signal strips the size of an A4 piece of paper and about as thick as a bible. on second thoughts better take a bible as well
Posted: Wed Oct 08, 2008 1:50 pm
by Arnulf
peters wrote:Arnulf you could put the four stips on top of each other then fold the breadth in half, then roll the length up in 250mm and you'll end up with the signal strips the size of an A4 piece of paper and about as thick as a bible. on second thoughts better take a bible as well
..........and water, and a first aid kit, and tie-downs, and tools, and........................
I am so glad that my trike has a 912 motor. Now all I must do is get bigger pannier bags to lug all this stuff around.
Posted: Mon Oct 13, 2008 8:22 pm
by bobthebuilder
Is a compass compulsory?
I dont have one on my trike.
Posted: Tue Oct 14, 2008 9:45 am
by Morph
bobthebuilder wrote:Is a compass compulsory?
Yes, CAR 91.04.4,
You need a magnetic compass, timepiece, Altimeter and Airspeed indicator
