Desperate for help. Setting up Icom A210 Radio
Re: Desperate for help. Setting up Icom A210 Radio
Postby Boet » Wed Mar 09, 2011 7:58 pm
You are welcome. Now I am sukkeling my gat off with mine. The damn intercom is driving me nuts. Ahhhh wellll.....RTFM. (**) (**) (**) (**) (**) (**)
Oupa-G
Postby Oupa-G » Wed Mar 09, 2011 11:06 pm
It is a wonderful radio, the actual fitting at the back of the tray is a bit mickey mouse so watch when you slide the radio into the tray, With the handbook the settings are easy without the book you are lost. On a recent trip with the Vansin I spoke to a Comair flight at least 300km away . We were both at altitude but even so the quality is ICOM.
Cheers Oupa-G
vernon11
Postby vernon11 » Thu Mar 10, 2011 8:11 pm
Oupa-G wrote:It is a wonderful radio, the actual fitting at the back of the tray is a bit mickey mouse so watch when you slide the radio into the tray, With the handbook the settings are easy without the book you are lost. On a recent trip with the Vansin I spoke to a Comair flight at least 300km away . We were both at altitude but even so the quality is ICOM.
Cheers Oupa-G
Thanks oupa G.
I am hoping to get into the air tomorrow to give it a good go, but I am sure it will be fine.
Vernon. (^^)
vernon11
Postby vernon11 » Thu Mar 10, 2011 8:16 pm
Boet,
If I get to the field tomorrow, I intend going through the menue and making note of all the setting of all the functions, so if for any reason of changes, I will know what to do. If you like, I will send all the setting to you, when once I have tested. That I am, sure will sort youy problem.
Vernon. (^^) (^^) vhpy vhpy vhpy vhpy vhpy vhpy vhpy vhpy
Postby Boet » Thu Mar 10, 2011 10:01 pm
Thanks Vernon, this will be muchly apreciated! vhpy The voice activated part is too sensitive. It is driving me nuts, and I can`t get the darn thang switched off. Ek het die blik%$@!m al gemik met die .44 Magnim EN n groot hammer!!
Oupa-G
Postby Oupa-G » Thu Mar 10, 2011 11:07 pm
In the menu you can set the sensitivity of the intercom mikes
Cheers Oupa-G
vernon11
Postby vernon11 » Sat Mar 12, 2011 12:54 pm
Boet,
You have PM.
Vernon
Users browsing this forum: No registered users and 41 guests
