Help needed on build issues
Re: Help needed on build issues
Postby Duck Rogers » Fri Feb 11, 2011 2:32 pm
Congratulations Trev.............. (^^)
Wishing you good luck. Keep us informed on the progress once you start building..
Go Vert
Postby Go Vert » Fri Feb 11, 2011 8:26 pm
sailor wrote:Hi Go Vert, Congrats and goodluck with your purchase. Tell Glin he can pay my commission into the microlighters account. :lol: :lol:
Do you perhaps know if the jabbie engine is still availabe?
Don't forget to post some pics of the project.
Louwtjie Vosloo.
When I last spoke to Glin the Jabi is still availble but a few people are keen
KFA
Postby KFA » Fri Feb 11, 2011 8:49 pm
The aircraft will have to be tested as well in terms of requirement contained in Part 24.01 and supported by the Technical Standards CATS-NTCA Part 24.01.2.A.7. for amateur built aircraft.
If someone can simplify that for me I will only have the time to check out act tomorrow afternoon.
Like someone said, this could be the beginning of the end. I say again, make dead sure from the engineering department that they have all the aicraft data on file. If they have none, then stay far away from the project unless you are an engineer or if you have money to throw at the project. If they do not have substantiating data for that aircraft type, you will have to supply all that according to a certification basis like the ASTM LSA or CS-VLA. This could be a very costly excercise. Ask us, we are/have been there.
This being said, Good Luck with the project.
Go Vert
Postby Go Vert » Sat Feb 12, 2011 4:45 am
Duck Rogers wrote:Congratulations Trev.............. (^^)
Thanks Gerrie, have alot on the table now with this one and the Ravin :roll: . Some hard work is required
Go Vert
Postby Go Vert » Sat Feb 12, 2011 4:52 am
Thanks for all the info Stephan, I have been in contact with FFP as well as some chaps who have also had similar obsticals and it seems that static load tests will have to be done. FFP is a great help though and are prepared to comunicate with any party and supply info in order to assist in any way. The chap over there named Paul gives super and I mean super service to the point of even discussing options and issues with me on a Sunday afternoon. So Im sure it will be atleast a month or two worth of extra effort with CAA but it will be worth it
